Help!! 700r4 trans wiring missing...
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
Ok.. first of all i got a transmission built a while back by a company. They set up the transmission for a vehical without electronics. They said the put ball valves in and such. No wiring is on the valve body. The transmission shifts horrible! Will not even do a wot shift. Plaese help
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
I don't get what you are trying to say but the wiring in the valve body is only for the lockup function of the converter. Unless, you have the 4L60E and that is a totally different explanation. I don't understand how you setup a trans for a vehicle "without electronics." I would most definately make sure you have the TV cable adjusted properly. At the very least, take the car back to shop and tell them to adjust it. If they screw it up then they have to fix it.
1992 Trans Am
05-10-2023 07:19 PM
eightsixseven
08-14-2015 03:09 PM
