I have a 2.73 rear right now, wan't to chang the ring and pinion but need your help.
Old May 30, 2006 | 07:43 PM
WaOnFiRe's Avatar
Car: 1988 Pontiac Firebird Formula 350
Engine: 5.7L
Transmission: Automatic 4 speeds
Axle/Gears: 2.77
I have a 1989 Chevrolet Camaro IROC-Z that I just bought. It have the original 2.73 disc POSI rear end right now in it.
What years ring and pinions will fit without modification? I know I could buy some smaller ones from previous years and adapt it, but I would like something that fit easily.
So in what cars and years would I find something for me?
Maybe you know a web site selling new ones cheap or know where I can buy used ones?
Thanks!
Old May 30, 2006 | 08:37 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Nothing will fit the 2-series carrier in your 10-bolt. You will require a spacer or thicker gear set made for that carrier.
Old May 30, 2006 | 08:49 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
any 10bolt 2 series gears will work. If you want to go with some decent gears int he back, like stated above you will either have to use puprose build 3 series gears made to fit a 2 series carrier or use a shim.
Old May 30, 2006 | 09:20 PM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
I just received an offer from someone, so could you tell me if the gears he have for sale are the same thickness than mine?
Would it be easy to swap?
Here his message:
"have a set of 3.23's from a 92 RS in good shape. $50 shipped for whole assembly. I may have a set of 3.42's from an 89 2.8 5 speed car $65.00 shipped for whole assembly. i will not seperate ring gear from pumpkin, it all gets sent as a complete assembly.........."
Old May 30, 2006 | 09:42 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
both of those are 3 series and will NOT be a direct bolt in.
3.08 and numerically lower = 2 series
3.23 and numerically higher= 3 series
IF they send the pinion to match it shouldnt be a problem as long as the axle splines are all correct.
Old May 30, 2006 | 09:44 PM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
Oh well, I'll just have to pass then, I'm no mechanic and where I live no one is specialised in that...
Old May 30, 2006 | 10:28 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
If you can find the complete rear end its just a matter of a case of beer and a few day to swap the whole thing in. Nothing special or technical there.
Other than that, swapping out components requires you to do some precise shim work to get everything lined up right and if its not you will get one heck of a howl coming from the rear and chew up a set of gears in a hurry.
Old May 30, 2006 | 11:39 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Just swaped from my 2.73's to 3.42's with a set of Yukon Gears from Randys Ring and Pinion.
Old May 31, 2006 | 12:30 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Some 3.23 gears are 2 series. Mine are. What ratio do you want to use? If you are ok with a set of 2 series 3.23 gears, that would be "easy". Otherwise you'd need to get a new posi unit to go with it if you wanted to go to a higher numerical ratio.
Your '89 car is on the changeover year, so you either have 26 or 28 spline axles. If you have the axle taken apart, count 'em and check.
That guys selling his gears says "will not seperate ring from pumpkin", that makes no sense.
Ask if he means "will not seperate ring gear from carrier". Then ask if the carriers are posi or not. Then count your axle splines, and see if his match. Then you'd be set with either of his that match your axle spline count.
So, to sum up, you need your axles spline count, to match the spline count on the carrier (your posi unit). Your ring and pinion don't care about the axle splines, but must be the correct series for your carrier (posi).
capisce?
hectre13
Dec 11, 2023 08:14 AM
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
hectre13
Aug 26, 2015 08:17 AM
