Kick-Down Throttle Adjustment
Old Jun 4, 2006 | 06:44 PM
Cam-aro's Avatar
Car: '91 Z28
Engine: L98 H/C/I - 400whp
Axle/Gears: Moser 12-Bolt(4:30 w/spool)
Right now my car is in about 6000 pieces being modded/fixed/updated... but ever since I purchased the car, the kick-down does not function properly. When at WOT(wide open throttle) the car does not downshift... it only accelerates from the current gear. The kick-down throttle is properly connected at the transmission and by the throttle-body and appears to function properly. Inside the transmission, one can toy with the kick-down line and the tranny appears to react fine. Could too much slack cause a failure? Any other ideas? The car is being finished tomorrow morning/afternoon, lemme know please!
Old Jun 4, 2006 | 08:34 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
It sounds like the TV cable isn't doing its job. How is the trans shifting? The TV cable will alter the pressure in the trans and cause the shifting to suffer also. If everything else is ok, I would think there is a problem with the valve or the cable could be stretched.
Old Jun 4, 2006 | 10:20 PM
Cam-aro's Avatar
Car: '91 Z28
Car shifts perfectly fine... just shifts at low RPM's in Drive(even when full-throttle). I've heard that because the tranny was to come stock with a manual valve body... it overrides the kick-down.
Old Jun 4, 2006 | 10:41 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Ok, sorry but 'one Cannot toy with the throttle valve cable'
It has one and only one correct setting.
It is not like the earlier trannys which have a kickdown cable, this is a throttle valve cable which tells the tranny what the motor is doing and adjusts line pressures accordingly.
Basically the TV cable does the job of both the kickdown cable and the vac modulator of the earlier trannys.
Now your mixing me up with the manual valvebody bit. Is it, or is it not a manual valvebody?
Old Jun 4, 2006 | 10:59 PM
Cam-aro's Avatar
Car: '91 Z28
That, I do not know for sure. The previous owner told me the car had a B&M Street/Strip 700r4, and I asked him about a manual valve body and he said no, but he had no idea. We pulled the tranny today to discover it was a Hughes Street/Strip 700r4. Everything I've been reading says the Hughes Street/Strip comes stock with a manual valve body... all I know thus far, correct me if I'm wrong.
Old Jun 4, 2006 | 11:06 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
hughes builds them in both full auto or full manual.
P#74-1 = full auto
P#74-2 = full manual
Old Jun 5, 2006 | 10:22 PM
Cam-aro's Avatar
Car: '91 Z28
P#74-1 = full auto
Alright, well looks like I'm running with a 'full auto'. Here's a picture of the transmission and the build tag.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
J-money
Jan 4, 2019 09:45 AM
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
greenyone
Sep 8, 2015 08:41 PM
Randomtask2
Sep 7, 2015 05:06 PM
