How To Spot Manual Valve Body?
Car: '91 Z28
Engine: L98 H/C/I - 400whp
Axle/Gears: Moser 12-Bolt(4:30 w/spool)
My car has a Hughes Performance Street/Strip 700r4. I'm curious to whether it has a manual valve body or not. Right now, the tranny is on a transmission stand and the shell has been opened so I can easily get inside to look at it... how would I know if my tranmission has a manual valve body? Certain things to look for?
Car: Iroc-z 86
Engine: 350 4bbl
Transmission: built up 700r4
Axle/Gears: ls1 4.10 posi
theres way to see that its a manual valve body.....but like mine we put a manual shift kit from transgo and if i put it in od im in 4th gear....you will know it whe it will be install on the car
Seb
Seb
Car: '91 Z28
Originally Posted by RBob
Pull the governor and see if it has a spring to deativate it.
RBob.
RBob.
Car: 92Z28,91Z28,91Z281LE,95ZR-1,08Z06
Engine: 406, 350, 305, 350, 427
Transmission: auto, auto, 5-speed, 6spd, 6 spd
Axle/Gears: all stock
Originally Posted by Cam-aro
Deactivate what? The valve body? From what I've read though... the Hughes Street/Strip trannies came with manual valve bodies. But I dunno, I'm confused!
Car: check
Engine: check
Transmission: check
RBob.
Car: '91 Z28
Sorry, if the governor is deactivated. Since it isn't used the weights are normally tied up (outward I believe). This would be for a full manual setup. Where the transmission is always in the same gear as the shift selector is in.
RBob.
RBob.
Car: check
Engine: check
Transmission: check
Between 'full manual setup' and 'no manual setup'? A stock 700R4 will upshift to 2nd even with the selector in 1st. This can be changed with a reprogramming kit (such as a TransGo). AFAIK that is the only in-between that I know of.
A true manual will always be in the gear the selector is in. Such as if at a stand still with the selector in 3rd, the vehicle will pull out with the transmission in 3rd gear. Not good for the trans.
My car stays only in gear selected, but if I put it in OD while car is still in 3rd... it'll wait to shift till OD until the rpms haven't gotten to a shift point.
If when at a stop you put the selector in 3rd, does it pull out in 3rd? Or does it start in 1st and upshift to 2nd, then 3rd? If it pulls out in 3rd then I don't really recommend doing this as it will kill the 3/4 clutch packs.
RBob.
RBob.
Car: Iroc-z 86
Engine: 350 4bbl
for the kick down cable it need to be there even if you have a full manuel trans....since the kick down is not there only for shifting, it boost oil pressur at Wot.....so if you remove the cable your trans will live about 1 mile even if you have a shift kit.
Seb
Seb
Car: '91 Z28
Car: check
Engine: check
Transmission: check
... when in first, the car stays in first, will not auto upshift. If I put the car in Drive though, the car will shift from 1st thru 3rd as needed.
And the trans will downshift as required by the shifter.
RBob.
1992 Trans Am
May 10, 2023 07:19 PM
backtothe80s
Sep 5, 2015 12:39 AM
