1995 z28 rear end
Old Jun 11, 2006 | 01:01 AM
ckjoshz28's Avatar
1995 z28 rear end
actually this question is really for all rear ends.
I have a leak in the front of the rear end, where the driveshaft yoke enters and gets bolted to the u joint. what do i need to replace?
thanks
Old Jun 11, 2006 | 01:40 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
The technical name for it is a pinion seal.
Old Jun 11, 2006 | 10:23 AM
ckjoshz28's Avatar
is the pinion seal pressed in or is it held in by the u joint assembly? And could you give me the average time this job would take to complete?
thanks
Old Jun 11, 2006 | 01:09 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
As with most seals, yes it is pressed into the housing.
Depending on your skills, it could be a couple hour job.
Old Jun 14, 2006 | 12:30 AM
ckjoshz28's Avatar
A friend of mine said i had to take the rear end apart to change it. Mind you he owns a mustang so his pinion seal may be different.
But anyways he is saying i have to take the axles out posi out and remove the pinion out of the back of the rear to swap seals. Any truth? I doubt it based on your saying a couple hour job.
Since taking off wheels, brakes, axles, posi, swapping the seals and re-assembling would take me the better part of a day.
Droping the shaft, wedging a seal off , tapping a new one in and filling up the fluids is an hour maybe a little over depending how hard it is to come out.
thanks for any clarification.
Old Jun 14, 2006 | 11:25 AM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Check for bearing play. You might replace a seal, when you also need a bearing too.
Old Jun 14, 2006 | 12:29 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Sounds like your buddy was talking about axle seals.
The pinion seal requires you to unbolt the driveshaft, pull the yolk and pop out the seal. Its not a very lengthly project but may take a few hours depending on your skill level.
Old Jun 14, 2006 | 05:02 PM
ckjoshz28's Avatar
okay sounds good.
and in addition to my pinion seal....
i have an oil leak in the passenger side of my 305. Its dripping onto the starter area and then on to my header's collectors. Its not the valve covers. So i take it i have 2 culprits...rear main seal (85 is one piece iirc) or intake gasket?
just making sure.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
