Tranny Swap!!
Car: 88 IROC-Z
Engine: fully built 383 stroker
Transmission: Tremec TKO-600
Tranny Swap!!
i have just started on my tranny swap! im swapping my 700r4 (modded) with my new Tremec TKO-600 5-speed! it will be soo nice! anyway i just attached the adapter plate, bellhousing, clutch fork, and throwoutbearing! here are some pics! soon be done by monday! keep you guys posted!
http://i45.photobucket.com/albums/f9...s/DSCF1354.jpg
http://i45.photobucket.com/albums/f9...s/DSCF1355.jpg
http://i45.photobucket.com/albums/f9...s/DSCF1356.jpg
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
That should be pretty sick when you get her all together. Keep us posted on putting the pedals in, Hydraulics, And the shifter. I'm looking at doing a manual trans swap myself. Good luck!
Car: 88 IROC-Z
not a problem! will do!
thanks!
Car: 87 Trans Am
Transmission: TKO 600
Ive been thinking about doing the same swap. But I was going to use a stock bellhousing. I have a blown up 700r4 and been debating between a Probuilt or a TKO 600 manual swap. Definetly keep us posted on the progress
Car: 88 IROC-Z
ok! the tranny is almost out! but i have tomorrow and sunday to finish so ima take a break! the only trouble i am having is getting the tranny out of the car, it's got a jack underneath it and when i let the jack down, it comes down, but i cant seem to wiggle/pull the damn thing out
, so ima take a break and relax and get bak to it later! ooh! pictures to come! when i get it out!
Car: 87 Trans Am
Were you able to get the trans out??Yesterday I ordered a TKO 600 I can't wait to get it so I could start the swap too. I've had many manual cars but never a V8 car with a manual so this is going to be pretty cool. Good luck with the rest of the swap.
Car: 88 IROC-Z
Yah i got the tranny out! putting the tko-600 in today! and finishing everything up! hopefully i will be on the road by the end of today if not then by early tomorrow! let me know if you need any help with you swap!
Car: 88 IROC-Z
Originally Posted by superNOScamaro
hey UgotSmoked where did you buy your transmission from and what came with it?
what are you looking to get? Last edited by UgotSmoked; Jul 20, 2006 at 05:03 PM.
Car: 91 CAMARO RS VERT
Transmission: t-5
Axle/Gears: 10 bolt/3.08
im looking to get a tko 600 i just want to make sure that i can get everything i need and tech help if needed for my t-5 to tko 600 swap in one place. i have heard of fortes having good service and i think i might go with them or 5speedtransmission.
Car: 88 IROC-Z
Transmission: t-5
Originally Posted by UgotSmoked
well let me tell you that fortes is the distributor for 5speedtransmission.com, if you order from them you get your stuff from fortes...might as well order from fortes themselves...delete the middle man you know? i ordered from 5speedtransmissions.com and it all came from fortes, so yah! ahaha!
yeah i found that on my own about 10min ago, now i feel dumb. anyways how long did it take to get your transmission?
Car: 88 IROC-Z
Car: 1986 IROC camaro
Transmission: auto stock
Axle/Gears: 3:42
hey i have been thinkin about swapn my tranny for a wile. how much is the whole swap costin ya
Last edited by camaro2116; Jul 23, 2006 at 03:38 AM. Reason: Automerged Doublepost
Car: 88 IROC-Z
Originally Posted by camaro2116
Thats sweet man i been thinkin about doin that for a wile. how much is all of it costin ya
well im doin the whole swap myself, so free labor charge ahaha but all the parts to swap from a auto to a TKO and shipping is about $3,700.00 for all the parts u will need including flywheel, clutch, pressure plate and all that good stuff! and the shipping is with that price too...
Car: 87 Trans Am
I'm thinking of using a Lakewood bellhousing instead of the stock one cause the one I won on ebay has screwed up threads. Was it hard to set up the Lakewood bellhousing? Do you think you'll have any ground clearance problems with bellhousing. I'm running sportline springs so I'm alittle concerned about that.
Frank
Frank
Car: 88 IROC-Z
Frank
Frank
not hard to set up. clearance is good, except starter. have to get the after market mini starter. but i have sportlines too and there is anough room! in fact i might even lower it more later on!
Car: 88 IROC-Z
Originally Posted by BigDreams92
Did your kit come with a pilot bearing?
Car: 1992 RS
Engine: Vortec Headed 383 9.6:1
Transmission: TKO600
Axle/Gears: 10 Bolt Posi 3.73
Which one did you use? The one with the clutch kit or the one that came with the transmission. My pilot doesn't fit over the inputshaft, is about .07" too small. It fits over the T5's just like it should though, and the clutch disk fits fine on either transmission.
Car: 88 IROC-Z
the one that came with the clutch kit...if it doesnt fit for yours then i dont know what to tell you...you may have to call wherever you got the clutch from and ask them. sorry! plus on my reciept it doesnt give me a part number or anything for the pilot bearing!
Car: 1992 RS
I think there's something wrong with my input shaft, I've tried all the standard GM pilot bearings and none of them fit over the input shaft.
Car: 88 IROC-Z
well, maybe you should call fortes or wherever you got the tranny from and ask what pilot bearing you should use...and then think about your input shaft. at any rate! good luck!
Car: 1992 RS
Just got off the phone with Mike Fortes. Says that the input shaft is larger and does require the use of a larger pilot bearing that should have been included in my box with the transmission. So I'm curious as to which clutch kit you bought and was able to use the pilot bearing as it seems it's not a standard GM size, which I believe is 1.094 O.D / 0.593 I.D. for bushings and 1.094 O.D. / 0.645 I.D. for needle bearings. The above measurements was as close as I could get with an ok pair of dial calipers, so they could be a few thousandths of an inch off.
Car: 88 IROC-Z
well maybe mine came with the transmission then...i ordered so much from fortes at once that they sent it all in three big boxes!
not that it was really a bad thing but i was just tearing open bags and putting it on the car like a kid at christmas! u know?
Car: 1992 RS
Yeah I know
I just don't want the pilot bearing to get here Wednesday or Thursday and have it really be an input shaft issue. My car has been up on stands for over a week.
Car: 88 IROC-Z
only a week? aha! your lucky! i have had so many issues wit my swap its been on stands for 6 weeks! and will finally be done by friday!
and its my DD!
i win!
and its my DD!
i win!
Car: 1992 RS
The car hadn't been driven in over 5 years until a few months ago, and I got 30miles out of the T5, to the exhaust shop, and home from the exhaust shop, barely. So been sitting again for about a month since then, just keeps dragging out on me.
Car: 1992 RS
Have you test fit the trans in the car yet? Would like to know where that shift bar ended up in the console.
Car: 88 IROC-Z
Car: 1992 RS
You're right, it does sit in there real nice. Got it in tonight after work, need some odds and ends bolts to get crossmember up but should be good to go after that.
Car: 88 IROC-Z
been a while!
i hope you guys are enjoying your tko's as much as i am! highly recommended to anyone who wants/needs to swap! runs great and looks beautiful! enjoy everyone who has one!
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
