4th gen rearend swap.
Old Jun 17, 2006 | 02:55 AM
ABJ88's Avatar
Car: 1990 RS/2000 Z28
Engine: 5.0/5.7
Transmission: 4L60/4L60E
Axle/Gears: 10 bolt/3.23
Going to do a 4th gen rearend swap need help. I've checked out a couple of threads even tech page. Very vague I want to do it right. Get cables, bracket, prop. valve, etc. Want to know every little detail. By that I mean I know the main sh$%, how to remove old, intstall new one. I've already done it, but not with 4th gen rear. Do I need special e brake cable, do I need a rear with or without T.C., E brake braket(make, use 4th gen one, modify), brakelines(use stock or buy Earl's stainless lines. Part #,etc.). I really want to have everything so I can get it done the first time. I really need this info my rearend is going out starting to slip(I know it's my rearend) and making alot of noise. I'm also thinking about using 4th gen master cylinder. Thanks!
Old Jun 17, 2006 | 03:01 PM
ABJ88's Avatar
Engine: 5.0/5.7
help anyone?
Old Jun 17, 2006 | 03:58 PM
tpi-hearse's Avatar
Car: 1989 Iroc, 1987and 1989 formula 350
Engine: 305tpi,350tpi,ls1
Transmission: 700r4,t-56
Axle/Gears: 3:08,3:27,3:23
bolts in the same....use a third gen master and disc proportion valve and use pbr ebrake cables(same as 4th gen)..I would use an early 4th gen without t.c......
Old Jun 17, 2006 | 04:15 PM
ABJ88's Avatar
Engine: 5.0/5.7
I want to upgrade to LS1 rear. I Forgot to mention that.
Old Jun 17, 2006 | 04:19 PM
tpi-hearse's Avatar
why? the rear changed in 1997 only difference traction control and brakes..more of a pain than its worth
Old Jun 17, 2006 | 04:31 PM
ABJ88's Avatar
Engine: 5.0/5.7
Better bang for buck. I tracked one down with 3.42 and of course bigger brakes. For $500.
Old Jun 18, 2006 | 02:06 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
no, it is worth the pain.
$500 sounds a bit steep for that rear, imo, but maybe I am just used to getting deals all the time.
I picked up an 01 3.42 rear with no brakes Friday for $150 and the LS1 brakes I've had I picked up for $125.
I ended up toasting my Eaton Posi last sunday and shredded the ring gear last night hence the reason I got the 01 rear..
Old Jun 18, 2006 | 03:31 AM
yuel's Avatar
Car: 91 z28
Transmission: 4l60
i agree its not worth the pain, i had a choice of 02 ls1 and went with 97 lt1, posi, 3.42, just had to buy new cables, i took me 1.5 hrs to exchange axle and back on the road. ls1 rotors are only slightly bigger rotors, but they have better parking brake. $500 is a little steep, but not outrageous
Old Jun 18, 2006 | 03:47 AM
ABJ88's Avatar
Engine: 5.0/5.7
They charge $100 dollar core charge and they sell only gm used parts. Found a couple other places for 400 but they seemed a little shady. I even had someone tell me over a $1000 and I laughed and asked him why so much he said: "Very good reliable and popular rearend" I told him what other people were pricing and he said: "They dont know what they have"
Old Jun 18, 2006 | 03:57 AM
yuel's Avatar
Car: 91 z28
Transmission: 4l60
$1,000 ha ha, i had a few people try to sell me one for $875, i told them to save them for the insurance companies, they might pay that
Old Jun 18, 2006 | 07:57 PM
ABJ88's Avatar
Engine: 5.0/5.7
Old Aug 8, 2006 | 05:47 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
www.tennesseeauot.com He sells the LS1's $325 and the LT1's for $300 I think.Complet hub to hub allyou need
Old Aug 9, 2006 | 01:45 AM
z28355's Avatar
Car: 83 z28
Engine: 355
i did this swap not too long ago to my 83 z but im not useing the ebrake stuff at all its laying around in the basement i used c4 corvette brakes instead of ls1 and i couldnt find a place in town to get the right fitings for the prop valve so i had to get a aftermarket adj. prop valve that worked out pretty well im useing the rear out of a 00 ss and it has the tcs sensor but it also is not used its just there to plug the hole in the rear end its not a big deal which style you use just find the cheapest one and build off that i got the rear w 3:43 gears and a posi minus brakes for 70.00 and found the complete brake setup on e bay for 54.00and then changed to a 4:56 gear from summit and thats all it works great and was pretty cheap you just got to ck around before buying a rear end i thjink i came out real well it just took time and patience
Warlocksirix
Sep 3, 2015 12:26 PM
cam-mike
Aug 24, 2015 07:23 AM
sreZ28
Aug 14, 2015 07:48 PM
