transgo install sheet vs video ...
Old Jun 20, 2006 | 08:52 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
On this step. the video shows them just taking the new parts, slapping them together and installing. Mentions no grinding of this shaft. wtf??
Old Jun 21, 2006 | 12:22 AM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
Maybe the paper is a revised edition and the video is a general overview.
Old Jun 21, 2006 | 09:24 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Both the old and new install sheet say to grind the land off. just curious if thats what everyone did.
-- Joe
Old Jun 21, 2006 | 08:42 PM
Section162's Avatar
Car: '90 Formula
Engine: L98 --> Ramjet
FWIW, I ground it off flush like it says. (I didn't have the video.)
Old Jun 21, 2006 | 09:13 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Me too.
Ya'll know if I can do the servo AFTER I bolt the valve body back in? I have the tranny on the bench.
I'm a littel concerned how i'm gonna flip the valve body onto the tranny (on the bench) without losing the check *****.
-- Joe
Old Jun 21, 2006 | 11:47 PM
Luther6704's Avatar
Car: 1986 Iroc
Engine: 305 TPI w/30,000 original miles
Transmission: 700r4 Transgo Shift Kit
you can use vasoline to hold the check ***** in place, be careful about setting the band tension. The video basically said :"not too tight, but not to loose" i ended up going to loose and burning the band up. Call transgo for specs maybe and use a feeler gauge to figure out the band slop
Old Jun 22, 2006 | 05:59 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I havn't gotten that far yet. oh well. guess i'll tackle that tonight.
-- Joe
Old Jul 2, 2006 | 11:13 AM
trannyman01's Avatar
grind the land off the valve
grind the land off .ive installed a bunch of these kits
Old Jul 2, 2006 | 07:47 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
thats what I did. Tranny's back in the car now. Now i'm dealing with a weird wiring problem.. ugg.
-- Joe
Old Jul 3, 2006 | 08:25 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Also a vote for grind it off :-)
A note for others installing TransGO stuff, always go by the instructions as they are revised as the kits change.
The video has been the same for however many years it has been out(still a good overview for peeps unfamiliar with trans')
later
Jeremy
Old Sep 30, 2008 | 10:27 AM
kosbo77's Avatar
Car: 1990 trans am gta
Engine: 5.7 ltr 350 stock
Re: transgo install sheet vs video ...
Where can I get my hands on one of these videos?
Old Sep 30, 2008 | 10:31 AM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
From Transgo
Old Sep 30, 2008 | 11:30 AM
kosbo77's Avatar
I figured that. I was just hoping that one may be online somewhere.
Old Sep 30, 2008 | 03:37 PM
metalax's Avatar
http://www.txchange.com/tgpvid.htm
Old Sep 30, 2008 | 04:57 PM
kosbo77's Avatar
Thank you very much metalax. I do appreciate it.
Vintageracer
Jan 10, 2020 05:33 PM
toronto formula
Nov 10, 2015 06:17 AM
Clean87TA
Sep 4, 2015 11:23 PM
crazynights
Aug 21, 2015 06:53 AM
