Changing From 1350 To Stock.
Old Jun 23, 2006 | 10:20 PM
L.I.N.Y.92CAMARO's Avatar
I pick up a spohn shortened driveshaft for my retro t56. But i have a stock 10bolt that will not allow me to run the 1350 u joint. How do i change this. I looked on the website and it shows from going stock to 1350 but i need to go from 1350 to stock?
Thanks,
Old Jun 23, 2006 | 11:02 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
If the driveshaft yoke is a 1350 and the diff yoke isn't, you need a conversion u-joint or an aftermarket 1350 series 10 bolt yoke. The factory GM U-joint "might" be a 1310 series so you would need a combination u-joint that fits a 1310 on one yoke and a 1350 on the other.
Since you already know the driveshaft is 1350, take the diff yoke into your local autoparts store and have them match up what u-joint is needed for that yoke. Then just get the conversion u-joint with that on one side and 1350 on the other.
It should be a common conversion u-joint. You can even make an oddball conversion u-joint by mix and matching different u-joints as long as you know what your are doing.
Old Jun 23, 2006 | 11:05 PM
So most Places will stock this kind of item?
I thought i was going to have to order it.
Where could i get a 1350 10bolt yoke
Old Jun 24, 2006 | 12:15 PM
bigdavesiroc's Avatar
Car: 87 iroc
Engine: 410 sbc
Transmission: tremec 3550
Axle/Gears: 30 spline 3.73
moser might sell one. check there first.
Old Jun 24, 2006 | 07:01 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Doing a quick search on Summit and Jegs, they have no listing for such a yoke but then they also don't list every item available. Only the more common items.
I really don't know if such a yoke is available. A huge 1350 u-joint connected to a tiny diff. Not exactly a common performance item.
Old Jun 25, 2006 | 10:43 PM
Car: 87 iroc
Engine: 410 sbc
you got a good point there! why make a bullet proof yoke for a grenade???
Old Jun 28, 2006 | 01:52 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
this is the one you need.
Spohn Performance, Inc.
italiano67
Dec 11, 2016 09:21 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
ChaseDale3and8
Mid-West Region
Aug 25, 2015 06:34 PM
overdriv
Aug 20, 2015 03:52 PM
NWAsonoma
Aug 18, 2015 05:45 PM
