TransGo shifkit and reprogramming kit? What's the difference?
Old Jul 2, 2006 | 08:38 PM
WaOnFiRe's Avatar
Car: 1988 Pontiac Firebird Formula 350
Engine: 5.7L
Transmission: Automatic 4 speeds
Axle/Gears: 2.77
Hello,
I want to make my transmission as best performing as possible (ultra quick shift and all...).
Looked at TransGo's web site and they have a reprogramming kit and a shift kit for 700-R4. What's the differences?
They also have a couple of other goodies.
What do I need from TransGo to make my car shift faster and all?
Old Jul 3, 2006 | 07:35 AM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
Old Jul 3, 2006 | 08:23 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Last I checked the shift kit is just that.
The reprogramming kit has the shift kit plus a lot of other features that you may want and even includes pieces you would have to disassemble the transmission for to intstall properly to fix issues that were in them from day one at the factory.
I would get the complete kit (with video if you know nothing of trans') and save the extras until u need a complete rebuild.
later
Jeremy
Old Jul 3, 2006 | 10:54 AM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
Well,
I didn't wanted to remove the transmission anyway so I need the normal shift kit right?
Old Jul 3, 2006 | 09:19 PM
Casey Butt's Avatar
Car: 1988 IROC-Z TBI
Engine: L04.3 = 305-310-336
Transmission: TH-700R4
Axle/Gears: 10-bolt, 3.42 posi
Originally Posted by WaOnFiRe
Well,
Get the full TransGo "Performance" Shift Kit for the 700R4. It contains everything you need to "reprogram" the valve body, plus the valve for the pump and the "Corvette" servo. Get the one with the video that walks you through the installation.
The kit will also include a pack of stiffer springs for the overrun and 2-3 clutch assemblies. These springs allow the transmission to safely tolerate higher RPM, but they have nothing to do with the "shift" kit, or reprogramming aspects of the kit. If you ever rebuild the transmission, you should install those stiffer springs, but if you don't install those springs it will make no difference to the reprogramming of the shifts whatsoever.
There's nothing inside the housing of the transmission that programs the nature of the shifts (other than indirectly by having better friction properties, spring pressures, etc). The shift characteristics are directly controlled by modifications to the valves and apply pistons (as the shift kit does).
Overall, the performance shift kit is the best deal because you get the Corvette servo included and the instructional video. You don't have to remove the transmission from the car to install it.
Old Jul 5, 2006 | 10:21 PM
Vortex91's Avatar
Car: Camaro RS '91
Engine: 305 TBI
Transmission: Auto w/ TransGo shift kit
Contact Dana at Pro Built Automatics, he knows everything there is to know about the TransGo kits, I've got mine from him.
Just run a search for "Pro Built Automatics" username (Search -> Advanced)on the forum and his posts will be displayed; a lot of them deal with the TransGo kit.
The reprogramming kit does not come with a video but if you read the instructions 4-5 times it will start to make sense and if you need help Dana is always willing to help and so are other people on this board.
I'll be done with my install this week (half way there) and hopefully when all is done I'll put it on the net.
fasteddi
Sep 2, 2015 10:29 AM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:14 PM
1Aauto
Sponsored Vendors
Aug 24, 2015 03:40 PM
crazynights
Aug 21, 2015 06:53 AM
dhonda200
Aug 11, 2015 11:50 PM
