help, need to know how not to install clutch backwards
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
hi, i have a spec stage 3 clutch, i just want to know what side goes where. i dont want to install it backwards thanks..
I'm not positive on a T56 style clutch, but I know on most clutches, the flywheel side just has a little cone that sticks out from the center of the disc with the rest being perfectly flat. The pressure plate side has a raised hub with the springs in it. The raised hub usually sticks up about 1/2".
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
thanks. i installed it so the spring hub was facing the pressure plate. i just wanted to make sure before i placed tranny on the engine... i bought a new clutch cuz my old one was slipping.. guess what..in the wrong way..lol.. thanks
Car: `86 SS / `87 SS
Car: 87 trans am
Engine: 350 TPI bored .040 over
Transmission: modified 700r4
Axle/Gears: stock spline, 3.73 Eaton posi
just make sure that the springs face the flywheel we did a clutch swap on my buddys car and the factory labeled the clutch wrong. when we put the side that said i think flwheel, we couldnt get the tranny to go it, flipped it around and it went right in.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Originally Posted by jmd
On an LT1 T56 with stock style clutch, the centre hub part sticking out goes towards the engine. On all other F-body setups, it goes towards the transmission.
LT1's are different. Thread Starter
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
EVERYONE KEEPS SAYING STOCK CLUTCH, I HAVE AN AFTERMARKET ON.. IS A SPEC STAGE 3.. DOES THAT MAKE A DIFFERANCE..
rsrmoore
Aug 7, 2015 08:44 PM
