Shifter cable clip on transmission
Car: 1989 Trans Am
Engine: 1989 305 TPI
Transmission: 700-R4
Axle/Gears: 2.77 10 bolt
Hi all,
I had a bit of an accident with my car the other day. I put the car in park and later turned the engine on. The car immediately drove itself forward and smacked into my mate's garage. The cause of this was the clip that attaches the shifter cable to the side of the transmission on my 700-R4. This clip had come off when I put the shifter into park and the transmission remained in drive, and cos when I started the car, the computer saw that the shifter was in park and thought it was OK to start the car. Anyway...
Could someone tell me exactly how this clip should install? Or better yet, would someone mind taking a photo or two of the underside of their car of this clip so I can get a real good look as to how this clip should install? It would be greatly appreciated.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The cable bracket is mounted to the transmission by two of the pan bolts. Sounds more like you've got a broken cable.
Car: 1989 Trans Am
Engine: 383 Carb
Transmission: 4L60
This is for an 82 Camaro, but the relevant bits should be the same. Which part are you missing?
Car: 1989 Trans Am
I'm after part number 15. Do you know what the official name for it it?
Car: 1989 Trans Am
GM calls it a control cable retainer, P/N 477093.
Just wondering if you wouldn't mind taking a photo of how it's installed or describing in some detail how it's installed, it really would be appreciated.
Engine: 383 Carb
Transmission: 4L60
I don't have anything around to take a picture of, sorry.
It should be pretty straight forward though, fit the cable into the bracket, then clip the retainer into a grove on the cable against the bracket.
Car: 1989 Trans Am
You're right, installing it should be pretty straight forward. But for one reason or another my clip pop off the bracket causing my car to smack into a garage. So understandably I don't want to repeat the event and want to make damn sure it's in place correctly, hence the request for a picture.
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 7, 2015 05:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
