How do I keep from killing my stock transmission?
Old Aug 10, 2006 | 07:06 PM
gregriggan's Avatar
Car: 1992 Camaro RS
Engine: LQ4 6.0
Axle/Gears: 4.10
I am about to install a stroker motor bored 60 over in my 92 camaro. It will be going from tbi to carb. What all do i need to do to keep from destroying my stock auto tranny until I can afford a beefed up T350? Any input would be appreciated.
Old Aug 10, 2006 | 07:20 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I'm no tranny expert, but I would guess the obvious - just take it easy. And make sure you get the TV cable geometry correct!
Also, there may be nothing you can do - it may already be toast without you knowing it. My tranny seemed to shift fine with my 305 - but when I dropped in my 350 carbed, the slipping started from the first mash of the gas - so I had to remove and get a rebuild.
Old Aug 10, 2006 | 07:37 PM
gregriggan's Avatar
Car: 1992 Camaro RS
Engine: LQ4 6.0
Axle/Gears: 4.10
Thanks for the advice. I will be taking it easy on the tranny for sure. I was just wondering if there were any tips you guys had for me? I hear that TV cable geometry is a must. So i will be extra cautious with this. Any other tips guys? Keep them coming.
Old Aug 10, 2006 | 08:17 PM
gregriggan's Avatar
Car: 1992 Camaro RS
Engine: LQ4 6.0
Axle/Gears: 4.10
ttt
Old Aug 10, 2006 | 09:38 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Keep it cool. 90K on my 700 with a 383 running 12's and no problems.
Old Aug 12, 2006 | 02:41 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
make sure you retain the lockup. add an aftermarket tranny cooler and install it in-line with the stock side tank. get a transgo shift kit( the one w/ the servo).
Remember detent cable geometry is more important than SN items above.
Old Aug 13, 2006 | 01:24 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
TPI 87 1/2 and later trans are the strongest in our cars.
Rebuild or acquire one to these specs or better at a minimum.
Rebuild it now before it breaks, it will be cheaper trust me.
Also verify TV cable pin length(at the TV plunger in the trans) as some were not the correct one the 90-92 years.
Trans GO kits are my shift improvement kit of choice.
later
Jeremy
customblackbird
Aug 15, 2021 10:16 PM
Cleotiz
Jan 6, 2018 08:56 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
InfinityShade
Aug 22, 2015 08:00 PM
