omfg wtf 700r4 servo help needed
Old Aug 15, 2006 | 12:01 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
been working on replacing my servo with an upgraded piece this morning and am having issues. The kit says that the servo can be changed with the trans in the car but i do not see how that is possible, i was able to remove the outer 2 discs but do not have the clearance to remoce the third cup looking disc or the pin/shaft. anyone else do this swap, or have this problem? really need help this is really frustrating
Old Aug 15, 2006 | 12:03 PM
Z28cross-fire's Avatar
Car: '94 Z28
Engine: LT1 350
Transmission: 4L60E/A4
I believe you need to drop the valve body to get the servos out.
Old Aug 15, 2006 | 12:05 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
the servo boss is in the side of the trans case cant remove it
Old Aug 15, 2006 | 12:27 PM
Car: '94 Z28
Engine: LT1 350
Are the servos open? If they are try pushing them closed. Can you take a picture of what you are talking about?
Old Aug 15, 2006 | 12:39 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
love to take a picture but dont have camera ready. there is a cast boss in the side of the trasnmission when the servo assembly in located. there is only about 1.25" of clearance between the lip of this boss and the body of the car, which is not enough room to remove the pin and the final servo plate. i need about 1/2 more room to remove these parts. i unbolted the trans mount and pushed the trans over as far as i can and still need 1/4 to clear... then after the part is removed, i have to re-install the new setup in 1 pc!? dont know if that will happen...
Old Aug 15, 2006 | 01:46 PM
Shagwell's Avatar
Car: projects.......
you'll probably have to drop the crossmember and lower the trans some....
....ever done servos? I'm guessing you haven't. - The servos are all on their own.
Old Aug 15, 2006 | 02:03 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Remove the four crossmember to frame bolts, Remove the driveshaft, Use a jack to support the trans as you slowly lower it enough until you have enough room to pull out the servo guts. That's what they mean by "in the car".
Old Aug 15, 2006 | 02:24 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
well i "think" i finally got it. holy F what a pain had to lower the trans and wedge it over as far as i could and i was able to just barely remove the parts...what a mess! just have to re-install the trans mount top off the trans fluid and see what happens thanks guys for the help.
Lol the package said "EASY IN CAR INSTALlATION" right whatever...
Old Aug 15, 2006 | 03:21 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
got it
what a difference
Old Aug 15, 2006 | 03:24 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Whenever you see a part that says it can be installed easily, they're not talking about a thirdgen.
Old Aug 15, 2006 | 11:15 PM
Car: '94 Z28
Engine: LT1 350
No I haven't, but I did stay in a Holiday Inn last night.
Old Aug 15, 2006 | 11:19 PM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
Can you explain the difference. Cuz I have my vette servo coming in the mail, and I am anxious to see what it does.
Plz. Plz. Plz.
Old Aug 16, 2006 | 01:57 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
the 1-2 shift is real snappy and the 2-3 is improved, well i could state whats on the box but thats useless
when i hammer the gas from a stop at idle it ripps, on second shift i am now actually having wheel spin issues that i need to address (need to tighten the lift bars up a bit on the right side)
i got a super servo and its cool as you read in my iother posts it was kind of a pain with a lot of cussing and griping at the car, but after a bit or pursuading it all worked out glad i did it.
Old Aug 16, 2006 | 01:58 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
lol
Old Aug 16, 2006 | 01:59 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
lol
Frozer!!!
Jan 19, 2024 04:55 PM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
