Best T-5 shifter?
Old Aug 22, 2006 | 12:53 PM
Jason E's Avatar
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
Best T-5 shifter?
I plan on ordering a B&M Ripper from Summit unless anyone has a better solution for me! The throws on the OEM shifter in my RS are noticeably longer than the OEM shifter in my Z28, and it really bugs me.
Any advice/opinions are appreciated!
Old Aug 22, 2006 | 01:26 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I have the B&M with Hammer T-shift handle (direct fit). I love it. However, everyone under the sun and moon will have a different opinion.
JamesC
Old Aug 22, 2006 | 01:52 PM
Axoid's Avatar
Car: 92 Camaro RS
Transmission: T5 manual
I've run a Pro 5.0 for over a year and half now and I'm very happy with it. I've driven a B&M on a T-56 and liked mine a little better, but that could be a little bit of bias.
After driving a Mitsubishi VR-4 a couple weeks ago that had a shifter soo vague it was hard to find nuetral, a stock T5 shifter fells good.
Old Aug 23, 2006 | 11:51 AM
drag1LE's Avatar
Car: 1991 Camaro 1LE Z28
Engine: 6.0L
Axle/Gears: Ford 9" 4.33
I love my Pro 5.0 shifter. Very well made and very positive shifts.
Old Aug 23, 2006 | 01:51 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I've had the Ripper and I am currently using the Pro 5.0 with a Lou's Short Stick.
go with the Pro 5.0
Old Aug 25, 2006 | 05:57 AM
Jason E's Avatar
Fair enough...where can I get one?
Old Aug 25, 2006 | 11:58 AM
Axoid's Avatar
Car: 92 Camaro RS
I think Thunder Racing carries them.
Old Aug 25, 2006 | 07:03 PM
Jason E's Avatar
Found it for $189, $10 cheaper than Jegs...works for me! I'm going to order it...
One more thing...will a Pro 5.0 accept the factory ****? Does anyone know where I can get a white cue ball ****?
Old Aug 27, 2006 | 05:29 PM
kaptinkafeen's Avatar
The factory **** works fine
-Andrew
Old Aug 28, 2006 | 06:21 PM
MixtureChicken's Avatar
Will any pro 5.0 shifter work, such as a used mustang unit, or do you have to get the f body version?
Old Aug 29, 2006 | 12:10 PM
I can't see a difference between the actual shifter itself, only the the stick. I was going to use a lou's short stick anyway so I don't see a reason to buy the fbody unit if I can get a used one from all the mustang freaks on ebay and then use a lou's stick.
Unless you guys know of a hitch there.
Old Sep 3, 2006 | 03:07 PM
I love asking questions when no one knows the answer.
Old Sep 14, 2006 | 01:18 PM
OK, no...
A mustang T5 has a different shifter pad design and it will not fit a GM T5.
Just in case anyone was wondering.
mcfastestZ28
Oct 5, 2015 07:12 AM
ndndndnd
Sep 28, 2015 08:00 AM
