700r4 out 4l65e going in few questions
Old Aug 23, 2006 | 09:55 PM
iwineng03ss's Avatar
Car: 2003 chevy silverado ss
Engine: 6L with twinturbos
Transmission: built 4l65e
Axle/Gears: 4.10
from what i have read and gather the stock drive shaft will work for my conversion. my stock trans from my 2003 silverado ss which is awd is going in my 88 firebird. now i know i have to change the tailhousing which isnt a biggie 6 bolts and its off and the 2wd tailhousing is on. my question is the front shaft from the drive shaft that goes into the trans will my stock one work or do i need to get one from an fbody with a 4l60e? probably a dumb question but just trying to gather what parts i need before the full on swap begins.. thanks for the help
Old Aug 23, 2006 | 10:32 PM
Axle/Gears: 4.10
Originally Posted by 12boogie
You do realise you need a TCU to run that electronic trans in your 3rd gen? If so, then disregard this warning. That trans also has a max rpm shift point of 5600 rpms. So if the current motor you are running exceeds this limitation then you should rethink this choice. Looks like you have quite a motor in the car right now and these issues could be a problem.
i will tune everything with my efi live tuning software for ls1 motors. just as i do with the truck motor and trans. i am waiting right now for my harness to get finished up. and as far as the shift points u can tune them anywhere u want my truck shifts somewhere around 5800-5900... maybe i didnt say it in the first post but i am doing a full ls1 conversion in the car..
camaro11j
Sep 19, 2018 08:49 AM
redmaroz
Aug 16, 2015 11:40 PM
djmarch
Aug 11, 2015 10:22 AM
Leggman1
Aug 6, 2015 04:15 AM
