need help with axle bearings- 9bolt
Old Aug 26, 2006 | 08:19 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
I just put a 9 bolt in my bird and I wanted to replace my axle seals because it looks like they are leaking
while I am at it I would like to replace the axle bearings but I heard that they are press on
I also do not know how to unbolt the axles so I would appreciate any advise on this
which bearings should I use?
Old Aug 26, 2006 | 09:18 AM
NoItsNotForSale's Avatar
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
Transmission: 700R's
Axle/Gears: 2.77 - 3.70
Yes they are pressed on. Once you remove the caliper and rotor you should see how to unbolt them. Timken #SET-9
Old Aug 26, 2006 | 05:32 PM
ede's Avatar
ede
may not be the recommended method but i burn the bearings off and use a pipe to press them on
Old Aug 28, 2006 | 09:47 PM
FIRECHICKEN's Avatar
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
The axles are bolted in from the outside behind the rotor. You undo the four bolts and the axles pop out. The bearings are pressed on and they must be pressed off to replace the seal. good luck finding seals. Make sure they match the old ones before you press the bearings back on. Don't forget to press on the retainer ring or you may have a problem if the bearing gets too hot. I hope you never need parts for that rear. You will be HARD pressed to find any replacement anything.
Let me know if you need a spare set of axles for your nine. I have a pair and an extra cover laying around.
Old Aug 29, 2006 | 01:59 PM
GMPARTSGUY's Avatar
Car: 1986 trans am
Axle/Gears: 373 9 bolt
TIMKEN SEAL #710179 FOR RIGHT SIDE
TIMKEN SEAL # 224255 FOR LEFT SIDE
TRY ADVANCE AUTO OR AUTO ZONE
6speedIROC
16
Mar 15, 2023 08:33 PM
cheesehomer
Dec 31, 2015 08:48 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
usafirebird
Sep 29, 2015 11:58 PM
rudolphschenker
Sep 4, 2015 02:41 AM
