Thinking of going back to a 700r4
Old Aug 30, 2006 | 07:44 AM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
Just figured out my clutch is pretty much roasted(or will be soon enough), Id love to have a t-56 but the cost is alot more then getting a Mad-Dog 700r4 with converter ( any idea if this guy is good?)
Apprantly the correct tailshaft and tv cable + mounting brackets are included
So heres the question Besides a stock shifter all i would need is the right VSS and a flexplate correct?
Thanks for any info!
Old Aug 30, 2006 | 07:54 AM
Bluejae's Avatar
Car: 1988 Formula 350
Engine: L98 350 TPI
Transmission: 700-R4
I've heard that the Mad-Dog transmissions are to be stayed away from. Apparently they are all happy to have you buy the tranny, but as soon as it goes bad then they have no customer service and will not do anything to help. It might be a wise investment in saving up for the t-56 and just be happy with it. Besides replacing your clutch will be cheaper than buying a new tranny.
Old Aug 30, 2006 | 08:10 AM
sprojam's Avatar
Car: 86 Z-28
Engine: 355 small block XR276HR roller cam
Transmission: TCI built 700r4 2000 lockup stall
Axle/Gears: moser axels auburn posi 3:73 gears
havent heard anything about maddog but bowtieoverdrives.com has good stuff an a excellent customer service dept the key to these trannys are gettin the tv set up correctly an bowtie will make sure you are there before burning it up two thumbs up
Old Aug 30, 2006 | 09:00 AM
fire350tpi's Avatar
Axle/Gears: 3.23's
Yeah but i mean i wanna do it right, With at least a spec clutch ( most likely needs a new fly wheel) then theres the t-56 itself and getting a good one.
i dont mind paying the money its just this car is the daily driver, and i dunno how long this clutch is gonna last i dont wanna get stranded and not be able to get to work it just seemed to me that a auto would be easier and cheaper by a big enough margin, BUT id obviously prefer the t-56 for sure
Old Aug 30, 2006 | 09:06 AM
sprojam's Avatar
Car: 86 Z-28
i think id keep it a stick im running a auto because its to exspensive to swap an my 700r4 is alot stronger then the t56 but you have the pedals an a setup for a manual now id keep it a manual good luck an please feep us posted on what you come up with
Old Aug 30, 2006 | 10:18 AM
fire350tpi's Avatar
Axle/Gears: 3.23's
Well i suppose my main thing is why spend 250+ on a clutch for the t-5 when id have to change it down the road, we all know my t-5 is gonna explode sometime lol so i dunno I guess the cheapest/most quickest option would be to just get a nice center force clutch and hope i dont blow the t-5 till i have money for the t-56 conversion
Old Aug 30, 2006 | 02:17 PM
Shagwell's Avatar
Car: projects.......
shouldn't you just buy a $100 HD parts store clutch and go on with life for now until you can afford what you want? - makes a lot more sense to me.....
Old Aug 30, 2006 | 07:08 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
yeah.. i guess thats the best option, id just prefer to put a good clutch behind it just in casei decide to do a g-force t-5 anyhow thanks for all the opinion guys
Old Aug 31, 2006 | 01:53 AM
Pat Hall's Avatar
Just wanted to reiterate what the other guy said about Maddog. Stay FAR FAR away from that guy! Do a search on here for maddog and see for yourself how many unsuspecting people he's screwed! If you want an awesome 700r4, there's no substitute for a Pro-Built automatic from Dana. They're expensive, but well worth it. Otherwise, just go easy on your T-5 until you can afford a T56 or a Tremec TKO.
Old Aug 31, 2006 | 01:02 PM
Shagwell's Avatar
yeah, I've heard/seen a lot of crap about Mad Dog 700r4's. - I personally like PATC(raptor), but I have never heard or seen any issues with Dana's transmissions.
- also, if you do a search you'll find a several reason not to waste your $ with G-force on their T5 crap.....
camaro11j
Sep 19, 2018 08:49 AM
midge54
Jan 29, 2017 07:00 PM
Reddeath210
Oct 6, 2015 08:20 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
Leggman1
Aug 6, 2015 04:15 AM
