need higher shift points from 700r4
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You need to change the governer inside the rear of the trans. Sorry I dont know more than that, but perhaps B&M or Pro Built has the right parts.
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
The kits has vague instructions. They simply say that lighter weights raise the shift points and heavier weights lower shift points. You will also find that the factory governors have same size weights on each side. Kit does not have 2 that match, making it more confusing. If you want to do it yourself, Start with 2 9 gram weights.
Car: 1988 Trans Am GTA
Engine: 350 4BBL
The problem with this is when you get the 1-2 upshift high enough, the 2-3 upshift is still too low. It's not just as simple as using lighter weights and lighter/heavier springs. To see what I mean click here. (sorry for the glare on the tach)
I pedaled the 1-2 shift at 6500 and the 2-3 is still too early at 5800.
You can't raise the 2-3 shift without raising the 1-2 shift into the stratosphere. Here's what that looks like: you can see it bounce off the rev limiter set at 6700 here. Somebody out there has found a solution to this.
If not, I'll post the answer when I figure it out . Last edited by Supervisor42; Sep 24, 2006 at 10:47 AM.
Engine: 350 4BBL
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Here is some info for you:
B&M governor calibration kit for WOT.....THIS IS JUST AN APPROXIMATION!!
GM#24202127 = 4400 rpm
Blue&Yellow 2 & 3 = 4900 rpm
GM#24202117 = 5000 rpm
Blue & Yellow 4 & 3 = 5100 rpm
GM#24202122 = 5200 rpm
Blue & Yellow 2 & 5 = 5300 rpm
Blue & Yellow 5 & 3 = 5500 rpm
Blue & Green 4 & 5 = 5600 rpm
Blue & Green 3 & 5 = 5600 to 5700 rpm
The GM Part numbers is for the actual governor.
These will vary with the stall.....higher the stall of your torque converter...the higher they will want to shift.
Engine: 350 4BBL
Let me add some stuff also from personal experimentation:
We won't even talk about where the "part throttle" shifts occur
Springs comparison tension from heaviest to lightest:
Heavy> purple, white(stock), blue, green, yellow, rust(stock), orange, red <light
Weights, weighed in grams from fulcrum, heaviest to lightest:
#1- 8.4g, #2- 5.7g, #stock- 4.5g, #3- 4.3g, #4- 4.0g, #5- 3.0g, #6- 2.0g
Stock setup:
White & Rust, #stock & #stock= WOT 1-2 5200 2-3 5000
Modified setup:
Red & Orange, #5 & stock = WOT 1-2 >6700 2-3 5500
Orange & Rust, #5 & #4 = WOT 1-2 >6700 2-3 5700
Orange & Yellow, #6 & #4 = WOT 1-2 >6700 2-3 5800
The "famous" corvette governor:
WOT 1-2 3600 2-3 3400 (you can really win with that!
You just can't move up the 2-3 shift much without running the 1-2 shift into the stratosphere.
.Springs comparison tension from heaviest to lightest:
Stock setup:
Modified setup:
)You just can't move up the 2-3 shift much without running the 1-2 shift into the stratosphere.
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I think that the thing to do is to get shifts a little below your ultimate. Install a good B&M shifter. For day to day stuff, just leave the shifter in D, but for the ulitmate races, use the shifter. If you set the shift points above where you want to shift, even if you shift up to the next gear manually, the tranny wont shift until you hit the shift RPM.
I wish that I know this stuff above before I experimented with the B&M calibration kit. I have had the govenor in and out 5 times.
Engine: 350 4BBL
Make that 10 times for me. Number 11 probably this weekend. Putting in a drain plug to get those 2 quarts into a clean jug to put back in saves time & money. You can call me lazy but manually shifting is not consistant. The auto trans will shift at exactly the same RPM every time. And we all know about consitancy winning races...
WE just have to change something else besides the governor to bring the shift points at WOT back in line.
Car: '87 IROCZ
Engine: 395 ZZ4
YenkoST, I was not doubting you, just curious how one comes up with good stuff. Your info above is key to someone trying to get a specific shift point. It seems though, you cant get the 1-2 shift and the 2-3 shift to be at the same RPM. Why is it that the 1-2 shift is much higher than the 2-3 shift? And do you think other combos can get both shifts at the same RPM?
Supervisor42: I jack up the car high in the back, I dont loose any coolant except a few drops. I let the car sit on the front tires.
Car: 1983 G20 Chevy
Transmission: 4L60
I never have any trouble getting my 1-2, 2-3, and 3-4 shifts within a few hundred RPM of each other. My 1-2 was 4,800 and my 2-3 4,600, then 3-4 happened at 4,700. 1992 Van governor with lighter springs only.
With P295/50/R15s and 3.73 gears, 1-2 was at 38 mph, 2-3 around 65, and 3-4 around 110.
YouTube - Chevy Van 350 1
You will need the Corvette valve body that comes with the high upper RPM horsepower. I do not remember which engine, but this valve body should go to about 6,500 rpm at produce the WOT shift you like. The 1-2, 2-3, 3-4 shift timing valves are different in these, besides the lighter weight governor. I think these valve bodies were in 1991 or 1992.
Car: 1983 G20 Chevy
Transmission: 4L60
Engine: 350 4BBL
Now for the ultimate $64 question:
I bet the the valve body castings are actually the same (for the others of the same year model). Are just the springs different or are the valve spools and springs different? I got money. Just need something to buy. Can't see buying a whole new transmission (only to find it has to be manually shifted) when the one I have works fine (shift points not withstanding).
C'mon Pro Built, put together a spring & spool kit and sell 'em for $150-$200.
I'll buy!
Car: 1983 G20 Chevy
Transmission: 4L60
Now we're getting somewhere. I think I remember something about a 32 valve aluminum engine ZL-1??
I'll buy!
I'll buy!
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
someone972
Aug 30, 2015 12:52 AM
