T5 Swap on a 383.
Old Sep 23, 2006 | 10:49 AM
StrokedZ28's Avatar
Car: 86 Z28
Engine: 383
Transmission: Built 700r4
T5 Swap on a 383.
Ok so I plan on swapping my 700r4 for a WC T5. My question is since my car has a flex plate based off a 400cu SBC for the 700r4 what will I need to make sure the motor is still balanced with a T5?
Again, my 383 is externally balanced and uses a flexplate from a 400. What do I need to get to keep the motor balanced if I get a T5?
Old Sep 23, 2006 | 10:59 AM
Codename 47's Avatar
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
You will either need an externally balanced flywheel OR a regular T5 flywheel with a balance plate (little piece of metal that costs like 15 bucks).
Old Sep 23, 2006 | 11:06 AM
StrokedZ28's Avatar
Car: 86 Z28
Engine: 383
I take it speed shops should sell those things.
Old Sep 23, 2006 | 03:14 PM
Engine: 400
Yeah or just get one off of summit.
Old Sep 23, 2006 | 04:53 PM
StrokedZ28's Avatar
Car: 86 Z28
Engine: 383
What would I look under?
Old Sep 26, 2006 | 09:59 PM
Engine: 400
Whoops, sorry about the delay in the response.
This part number through JEGS will give you what you need.
383-624001
Old Sep 27, 2006 | 06:35 AM
https://www.thirdgen.org/forums/tran...ch-master.html
Old Sep 27, 2006 | 08:17 AM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
exactly, ive done this and am still fighting this, now if you make sure you compensate for the distance pushed back then you should be ok.
now mine already had the t5 in it, so thats why i tried it, but im already looking into stronger trannies because this one isnt gonna take a beating from my 406 for long.
ill sell you my t5 stuff if you want it though. weight and all
Old Sep 27, 2006 | 02:03 PM
Engine: 400
My system seems to be working ok? Or is this because maybe it hasn't broken yet? (I don't have any washers moving the slave towards the front of the car)
Old Sep 27, 2006 | 02:27 PM
Like I said n that other post, sometimes they work, sometimes they don't.
I guess you're just one of the lucky ones, and Randy isn't so lucky.
Old Sep 27, 2006 | 02:59 PM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
you said it sofa, im not one of the lucky ones.
if the guy wants to try it ill sell him all the stuff out of my car including the pork chop weight.
i havent popped this 3rd master cylinder yet.
key word yet
Old Sep 27, 2006 | 11:50 PM
StrokedZ28's Avatar
Car: 86 Z28
Engine: 383
Is it a WC T5? If so how much for everything?
Magman
Sep 12, 2015 10:43 PM
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
