My odd-ball transmission mount...
Old Sep 15, 2006 | 12:35 AM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
I recently discovered, after breaking my tranny mount, that the mount on my V6 T5 '89 RS was unlike almost every RWD vehicle GM made! My local parts store didn't stock it and said that they'd never seen one like it! The local GM parts dealer quoted me almost $300 for a new one! It seems that just about everyone has the "standard" mount and there isn't much info about the one I had. Thankfully, a couple guys on this forum pointed out that any cross member from '84-'92, along with the mount itself, would bolt right up to my car. Long story short, today I went to the bone yard and scored a cross member with mount (from an '86 SC) for $14 and it did indeed bolt right up!!! The pics are of the original mount (bottom) and the "new" one (top). In the second pic you can see the carnage that caused me so much grief!
Attached Thumbnails My odd-ball transmission mount...-transmount1.jpg   My odd-ball transmission mount...-transmount2.jpg
Old Sep 15, 2006 | 05:34 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Here's another odd ball of sorts:
https://www.thirdgen.org/forums/hist...ss-member.html
JamesC
Old Sep 15, 2006 | 08:08 PM
RSFreak's Avatar
Look closely at my pics. My new one does have that secondary spacer thing. From the responces to your post regarding this piece, it seems like it was primarily used on manual trans cars which is just fine since I have a T-5.
Old Sep 16, 2006 | 05:32 AM
JamesC's Avatar
You're right. My bad. I'm not exactly sure about the what or why of this piece, but it will work for you. I believe that GM still has the rubber bushings. I used poly. If I had to replace again, I might go with rubber.
JamesC
Old Sep 16, 2006 | 05:47 AM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
All of my thirdgens had that style crossmember for the trans.. two were auto v-8's and 1 was a t5 V8... I think they jsut used them in the early years perhaps of the thirdgen.
Old Sep 16, 2006 | 07:13 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
looks the same as the one that was in the 82 z-28 with 4 speed i junked out not too long ago
Old Sep 18, 2006 | 12:26 AM
Pat Hall's Avatar
Yeah, I've only seen that particular setup on the earlier thirdgens. I think they did it possibly as a vibration damper. If it works just fine, I don't see the harm in using it. But if it bothers you, you can always get the newer style without the secondary piece. Either of them are better than that stupid round donut mount though!
Old Sep 18, 2006 | 08:11 AM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
Transmission: Built 700r4
what you had was the rare, and used in 2 years only oil filled mount.
worst idea they ever had, used that mount in 89 and a short time in 90, and quickly went back to the standard rubber mount. '
that mount sells for like $300 at gm, and for the old/newer style its like $20.... was too uneconomical, even for gm...
Old Sep 18, 2006 | 05:06 PM
RSFreak's Avatar
Yeah no doubt! I wanna thank Pat Hall for pointing me in the right direction! You da Man!
Old Sep 18, 2006 | 05:59 PM
JamesC's Avatar
More like $90 if my dealership had it right.
JamesC
Hotrodboba400
Dec 10, 2019 07:07 PM
Rousseau92maro
Feb 1, 2016 05:12 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
