T-5 swap done have minor problems I need help with.
Old Sep 18, 2006 | 04:45 PM
Maroon89gta's Avatar
Car: 89 Trans Am GTA, 01 Ram, 01 Harley
Transmission: Worldclass T-5
I have swapped my 700R4 to a T-5 in my 89 Trans Am GTA. The process wasn't as smooth as I had hoped and wanted you all to know that you need to change your starter and starter bolts as they are different sizes. Also the problem I have, which is a minor one is the speedometer connections are different on the 1989 T-5 and the 89 700R4. So the problem is I need to get the T-5 connector and install it on my harness so I can get my speedometer to work again. Dealers and Parts stores and major internet part suppliers don't carry these and as far as I can tell my last option is salvage. Does anyone have one to sell or know where I can get one.
Also does anyone know how to get the check engine light to go away. I think it is the torque convertor signal going to the ECM that is giving the trouble, but didn't know which wires to jumper.
Old Sep 20, 2006 | 09:36 AM
Br1dgeman's Avatar
Car: Depends on what day it is..
Engine: Um, Chevy small-block
Transmission: One that shifts
Axle/Gears: Got those too...
Assuming you do not have a functional speedometer, the check engine light youare getting is most likely a Vehicle Speed Sensor code.
I am pretty sure you can still get the t-5 vss sender that goes into the tranny tail housing and the pigtail with the connector. I remember buying one when I swapped a Richmond 6 speed into an 85 corvette with the old 4+3 tranny. Unfortunately, I sold the car and the parts list went with it....
Old Sep 20, 2006 | 12:50 PM
Unfortunately the dealerships hear in Iowa don't have either part and can't get them due to they are discontinued parts. The only way I will be able to get them is through a salvage yard, a dealership with old stock and of course the internet via sites like this one. So far I have not bee succesful in locating one. I thought it would be a common problem for anyone who has done the swap and needs a pigtail.
Thanks for the reply...
Old Sep 23, 2006 | 10:01 PM
FOund my connector on a 1999 Camaro Wiring harness. Put it on and everything works, even the check engine light is gone.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Infested
May 22, 2018 11:56 PM
nuggie
Aug 25, 2015 01:27 PM
theurge
Aug 21, 2015 12:46 PM
sreZ28
Aug 14, 2015 07:48 PM
