Transmission Cooler Lines
Old Sep 20, 2006 | 09:16 AM
xjcamaro89's Avatar
Car: 1989 Camaro RS
Engine: 350 Holley TBI Personally Tuned
Transmission: 5 Speed
Ok, i got an automatic trans from a 85 iroc 305 LG4, the old trans cooler lines are about shot, we just dropped a new motor in, and I was wondering can I run rubber lines from the trans to the radiator where they hook up? I just wanted to make sure there isnt alot of PSI that would blow a line, or would the trans fluid eat or swell the rubber line? thanks!
Old Sep 20, 2006 | 09:59 AM
ede's Avatar
ede
you could run high pressure rubber lines, but it'd be a very weak link and a hack job at best. run steel or flexable steel lines.
Old Sep 20, 2006 | 10:04 AM
xjcamaro89's Avatar
Car: 1989 Camaro RS
Why would it be a weak link? Or a hack job?
Old Sep 20, 2006 | 10:38 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It's generally considered bad practice to run any significant length of rubber hose, since it's so vulnerable to being damaged.
Old Sep 20, 2006 | 10:44 AM
xjcamaro89's Avatar
Car: 1989 Camaro RS
Well its on a carbed LG4 ther are significant hoses run everywhere already for coolant or whatever
Old Sep 20, 2006 | 05:28 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
go to the parts store and buy some 5/16" brake line and bend it up and install. should be under $7 total. I believe i used the 52" length pieces for the top and slightly smaller for the bottom.
Old Sep 20, 2006 | 07:50 PM
Frank89IROC's Avatar
If you do decide to run rubber hose, go to a shop that cuts the hose to the length you want. Buy power steering hose (return line), cut to the length you need. This hose won't deteriorate from the fluid.
Old Sep 23, 2006 | 07:04 AM
ricktaylor's Avatar
Car: 84z28
Engine: 305h.o. mild mod's
Transmission: 700r4 shiftkit
trans line
I used trans line I bought from auto zone, the clamps I used are the type that are made specifically to not cut into the rubber the more you tighten them, I routed them the same way the hard lines used to be and securedthem with rubber coated brackets , it looks neat and clean and no rubbing, also no leaks at all.
deracer
Apr 11, 2016 12:04 AM
Reddeath210
Oct 6, 2015 08:20 AM
LittleFranks
Sep 17, 2015 12:22 PM
Dialed_In
Aug 20, 2015 01:45 PM
TreDeClaw
Aug 14, 2015 06:58 PM
