EATON OR AUBURN
Old Sep 23, 2006 | 10:16 AM
jd5944's Avatar
Car: 85 Camaro Z/28
Transmission: built 700r, B&M shift kit
EATON OR AUBURN
I NEED A POSI BAD .... BUT I DONT KNOW WUT ONE IS BETTER..... ANY IDEAS????????????????
Old Sep 23, 2006 | 10:58 PM
Coach Hawk's Avatar
Car: 91' Pontiac Firebird
eaton. You couldn't pay me to use an auburn posi. I've seen to many wear out prematurly, and they're not rebuildable by the home mechanic(they need to be sent back to auburn to have the friction surface remachined)
Old Sep 23, 2006 | 10:59 PM
thirdgenlover's Avatar
Car: 87 trans am
Engine: 350 TPI bored .040 over
Transmission: modified 700r4
Axle/Gears: stock spline, 3.73 Eaton posi
Eaton gets my vote , even thought i havent heard of auburn right off hand
Old Sep 23, 2006 | 11:06 PM
Car: 87 trans am
just curious jd5944, i know its off subject, but i always wanted to know what your rpms are at 60 mph with the 4.10s and having a 700r4, thats if your speedo is accurate after the swap. thought about getting them, but went 3.73s
Old Sep 24, 2006 | 04:29 PM
Coach Hawk's Avatar
auburn made all the factory posi's for F and B bodies through the LT1 years.
Old Sep 24, 2006 | 05:29 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
eaton is a better posi, stronger gear type setup instead of auburn's clutch/cone style. The auburns don't like hard hooks on drag tires.
Old Sep 24, 2006 | 08:59 PM
jd5944's Avatar
Car: 85 Camaro Z/28
sorry i couldnt tell u wut my rpms are at 60 cuz i got my car taken away bout 2 months ago for street racing but i can say that my speedo is WAY OFF..... at 60mph my speedo says 80mph.....sorry....how does your car run with 3.73's cuz ive thought bout it....im just wonderin if im still gonna have that low end power..... lots of people have told me thats wut i should do....idk...wut u think??
Old Sep 27, 2006 | 03:15 PM
Car: 87 trans am
with the 3.73s, at 60 mph, im at 2000, not bad at all, i just mainly wanted to have something that had performance but still be streetable. a buddy has 4.10s in his camaro with a t56, and he is around 2000 at 60 mph. i thought well if he has 4.10s and hes at 2000 and he has two extra gears that i dont have, i could only imagine what my rpms would be. you are at 4.10s now, what gears did you come from.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
dbrochard
Jan 28, 2016 08:42 AM
loud91rs
Oct 5, 2015 10:05 PM
dbrochard
Oct 3, 2015 12:43 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
