What rears are interchangeable?
Old Sep 27, 2006 | 11:48 AM
Liquid_Metal's Avatar
Car: Red '89 GTA
Engine: TPI LB9
I have a 9 bolt on my '89 GTA 305 manual. And I'm wondering which rears can be put on my car?? I'm thinking of replacing the old one because I believe it might be the cause of a shake problem (I have another thread on that).
My car is stock except for a deleted cat. So which rears from other cars will fit but still be as good or perhaps even better suited for my car performance wise than my original 9 bolt?
Old Sep 27, 2006 | 02:45 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
from a strength standpoint, 9 bolts are the strongest stock rear ends from thirdgens. any 10 bolt from a stock thirdgen would also fit, perhaps a 3.73 geared 10 bolt posi would be a nice swap. Unfortunately a stronger rear is also around $2000+ in the form of an aftermarket moser, strange, etc 12 bolt or 9" style rear end.
Old Sep 27, 2006 | 02:56 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Fourthgen rears are also a bolt-in option, though there may be some difficulties with the e-brake cables. The fourthgens are also, IIRC, a couple of inches wider per side.
JamesC
Old Sep 27, 2006 | 07:31 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Any third gen 10 bolt will be a direct swap. They all use the same external dimensions for the suspension. The fourth gen diffs will also bolt in but as mentioned above, they're about 2" wider per side so your third gen wheels will stick out.
If your 9 bolt has the PBR calipers, they won't swap onto a 10 bolt without some sort of mounting bracket fabrication. The early third gens have standard double flare brake lines. All the newer one use metric bubble flare so there's a few more things to think about if looking for a junkyard replacement.
Old Sep 27, 2006 | 07:37 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
They'll swap right on to a disc flange 10 bolt if the backing plates are changed.
Old Sep 29, 2006 | 05:11 AM
Car: Red '89 GTA
Engine: TPI LB9
How is the 10 bolt in comparison to the 9 bolt?
Old Sep 29, 2006 | 09:35 AM
JamesC's Avatar
As stated above, the 9 is somewhat stronger; it is, however, more difficult to find parts for.
JamesC
Old Sep 29, 2006 | 01:32 PM
Car: Red '89 GTA
Engine: TPI LB9
But if it's the strongest I find it hard to believe that IT is the cause of my problem. It's almost a stock car even. So it must be something else that is worn.
Old Sep 29, 2006 | 03:29 PM
JamesC's Avatar
The best and strongest wear out, both cars and men .
JamesC
Old Sep 29, 2006 | 07:35 PM
AlkyIROC's Avatar
Car: 87 IROC L98
The newest 9 bolt is now 17 years old. They don't last forever.
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
