long 1st gear
Old Oct 10, 2006 | 04:41 PM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
Transmission: stage2 700r4
Axle/Gears: 2.73 for now
long 1st gear
Mines an 87 305...700R4 w/ 2.73 gears. The problem is that when I floor it 1st gear hangs on forever. Its like the engine is @ WOT for a couple seconds until it shifts to 2nd. When it shifts to 2nd the car flies!!....Is this how its supposed to be. I mean the engine seems like its going to blow before it kicks into 2nd. Ive adjusted the tv cable a couple times, and it seems correct. Anything else you guys can think of. If i let off the throttle a little bit it will kick into 2nd faster, but i loose rpms??...whats wrong..
Shift kit maybe??
Old Oct 10, 2006 | 06:54 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
Move the TV cable 1 notch toward the front of the car. If it is worse, move it 2 notches toward the rear (effectively 1 notch back from where you had it.) Slight adustments like this are common and acceptable. Do not move it more than a couple notches from where you have it now.
Old Oct 10, 2006 | 11:24 PM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
makes sense....ill try it in the morning. thanks.
Old Oct 11, 2006 | 10:54 AM
Skull88's Avatar
Car: 1987 Camaro Z-28
Engine: 305 cu. in.
Transmission: Automatic
chang your transmission fluid
Old Oct 11, 2006 | 12:55 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
My 87 Trans Am shift out of 1st gear at 5500 rpms at WOT.
Keep that in mind. With a 2.73, it will take a little to get to 5500 rpms.
I have now changed my gear to a 3.73, and if shifts the same 5500 rpms.
Old Oct 11, 2006 | 01:16 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
My lg4 redlines at 5000 so that would be a problem for me. Mine shifts out of 1st a little over 3000.
junkcltr
Aug 2, 2019 11:12 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Warlocksirix
Sep 3, 2015 12:26 PM
gixxer92
Sep 1, 2015 04:32 PM
InfinityShade
Aug 22, 2015 08:00 PM
