lock up or not to lock up that is the ?
Old Oct 13, 2006 | 03:43 AM
roachjuice's Avatar
Car: 86 Omni GLHT
Engine: 2.2 Turbo/Intercooled
Transmission: 5 speed
Axle/Gears: 3:85
looking into buying a 3000 stall converter for my iroc... i have a lock up transmission right now... my ? is will having a non lock up converter in my car mess anything up??? because the non lock up converters are way cheaper than the lock up.... thanks
Old Oct 13, 2006 | 04:14 AM
Pro Built Automatics's Avatar
You will lose gas mileage, it will run hotter, higher rpm at cruise in OD, etc.
Old Oct 13, 2006 | 12:00 PM
roachjuice's Avatar
Car: 86 Omni GLHT
Axle/Gears: 3:85
cool thanks!!! so does a 3000 sound about right??
Old Oct 13, 2006 | 05:48 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
a 3000 stall should feel pretty good with that cam
Old Oct 13, 2006 | 05:57 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Like stated above, you will be looking at a slight loss in mileage and an increase in tranny temps.
You may want to look into a tranny cooler, its scary how only a few degree increase in trans temps can take 10 years off the life of it!
Old Oct 14, 2006 | 02:08 AM
roachjuice's Avatar
Car: 86 Omni GLHT
Axle/Gears: 3:85
well i do have two trans coolers... goes into the radiator first then to the external one.....
Old Oct 15, 2006 | 08:14 PM
RITTER's Avatar
Car: 1983 Buick Regal
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
do you hvae a good source for the non-lockup converter? I only want like a 2400 stall though
Old Oct 15, 2006 | 08:26 PM
roachjuice's Avatar
Car: 86 Omni GLHT
Axle/Gears: 3:85
found a company on e bay called monster and another called g-men....
Old Oct 16, 2006 | 02:31 AM
For the 10" non-lockup torque converter I would use the Continental. The 2,400 rpm stall will work well.
jrdturbo
Mar 31, 2016 02:58 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
kkirch15
Sep 30, 2015 04:44 PM
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
