too good to be true?
Old Oct 15, 2006 | 08:02 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
Well after searching on the web for along time i finally found a website that sells 3.70 gears for the borg warner 9 bolt 7.75" rear. There motive 3.70 for 182.00 dollers JawsGear.com is this too good to be true are is there really 3.70 gears available for my car for only 182 dollers? Also what all would i need to replace my 2.77 gears with the 3.70's?
Old Oct 15, 2006 | 08:53 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
would you want to keep using your posi unit? It would be a 2 series posi right? (assuming the 9 bolt does things the same way the 10 bolt does).
Old Oct 15, 2006 | 09:50 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
you'd need a 3.27-up carrier to mount those gears to it
Old Oct 16, 2006 | 06:18 AM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
i guess i can find a 3 series carrier used on the classified forums what else do i need to get these installed and how much would it cost to be installed. I hear 3.70 might be alittle to much for tpi but i think it will do just fine.
Old Oct 16, 2006 | 01:35 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
lol, I upgraded my 2 series to a 3 series so I could go with a 3.73. And Its not cheap! I spent $800.00 when I was all done. Anything over a 3.08.....your going to need to upgrade to a series 3. This was all richmond parts that we installed also. So take your time and keep looking. If you can pick yourself up a used one and save some money, you might be better off.
Old Oct 16, 2006 | 01:56 PM
Shagwell's Avatar
Car: projects.......
yeah, you'll have to change carriers, which may be hard to find. Motive makes a good gear, and in their own catalogue they list the 3.70 for the 9-bolt, so I'd say any company that sells motive can get it. You will probably also need an "install kit" which will have new shims to set the proper tolerances with the new gear. Any decent install kit will also have a pinion bearing and possibly carrier bearings. The pinion bearing is almost a must, and when you're there you might as well change the carrier bearings to eliminate possible future problems.
okfoz
Mar 9, 2017 02:35 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
