WTF ?!?!?!? 9 Bolt help
Car: 87 IROC
Engine: "400"
Transmission: Whiplash unit from CVT
Axle/Gears: Bolt-in 9" Moser
9 Bolt help requested
I coulda swore I had a 7.5 10 bolt. After re-checking last nite, I got the 3.27 9-bolt. What the heck am I supposed to do with this overpriced junk? I want 4.10s, but I'm not going to spend an arm n a leg for them. No way to swap out the carrier or anything? It's in an 87 IROC-Z. 1.8 60's stink!
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I think another member on here had posted a link to a source for some reasonably priced gears for the 9 bolt. Like $170, about the same as 10 bolt stuff. Scroll and find that, it was recent, I don't remember the site it was at though.
Why can't you swap out the carrier?
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
they make 3.70 gears for around $170-180....which is not bad until you price in the install kit which is another $160. So I have to decide do I want to spend $350 plus labor to put in some 3.70 gears instead of the 3.27 I have now or do I want to save for a 9" and know I won't break that instead.
The cheapest route to 4.10 gears is to simply find a 10 bolt rear to replace the nine bolt with. If you have about $2k to spare, I guess you could pick up a custom 9" or a custom Moser 12 bolt. When sticking with a stock rear, I'd much rather have a 10 bolt since the parts are a lot cheaper and available everywhere. The nine bolt may be marginally stronger, but the hassle of locating parts, the expense of them, and the fact that the only aftermarket ratio available is 3.70 makes them obsolete in my book. If you ever burn up the posi, which happens all the time, they're even more impossible to find new than the gears or other parts.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
3.70+ gears are too much for an L98 TPI anyway.
and my install kit was only 120 bucks from reider racing. cheapest i seen gears and install kit was 299 from Reider
Car: 87 IROC
Engine: "400"
I'm looking for a 10 bolt rear that I can throw my gears in. Any idea what cars are more likely to have a 10 bolt disc rear?
The best thirdgen cars to find a 10 bolt posi/disc rear from are any Z/28 or GTA between the years 90-92. These cars usually got the ten bolt with posi and the better pbr aluminum calipers. These years also got the stronger 28 spline axles as well. If you don't mind the rear wheels sticking out another 2" on each side, 4th gen 10 bolt posi/disc rears are even easier to come by. I snagged a 3.23 10 bolt posi/disc for my car out of a 91 GTA.
Car: 89 Iroc-z
Transmission: TH400
Don't assume that's what its for. I now have a nice lil 383 stroker motor w/ a 3500 stall behind it.
but up untill 98 the 10 bolts had auburn clutch type posi's (from what i read) and the 99 up had zexel torsen units. advantage torsen because clutch type posi's wear out somewhat quickly compared to a torsen. torsens lock up great for good posi action too!
Car: 87 IROC
Engine: "400"
I havent been able to find a pic of a 4th gen rear with Iroc wheels on it. Dunno if i like the idea of it sticking out that far.
Car: 89 Iroc-z
Transmission: TH400
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
Car: 89 Iroc-z
Transmission: TH400
yeah my 89 has them.. so 90-92 should definately have them...but 93-97 LT1cars have the same stuff as well.
You'll also need the pbr backing plates since they're different from the iron caliper ones, but they're quite easy to come by most of the time. Any of the ten bolt disc rears from 89-92 will have the right ones. There's a guy on ebay right now that has a brand new, fully loaded pair of pbr rear calipers listed with a starting bid of $149, which is not a bad price at all since they're brand new AC Delco ones. If you got these, the only other thing you would need is the backing plates. The auction# is 170041877484. Or you could contact Ebmiller88 on the boards here. He has all sorts of brake stuff for our cars, and would probably give you an even better price for all the stuff you'll need, including the backing plates, lines, etc.
Car: 87 IROC
Engine: "400"
Will the disc brakes off of my 9 bolt swap to a 10 bolt? All i could find at the boneyard are drum rears
Technically, you can make the 9 bolt parts fit. All you have to do is router out the holes in the backing plates a little. The holes on the axle housing flanges have slightly different spacing, but it's not much. I helped a buddy of mine do just the opposite. We managed to put his 10 bolt stuff on a 9 bolt rear by just routering the holes a bit. Hey, I just noticed Bowtye101 is selling the backing plates you need in the classifieds for $40.
UltRoadWarrior9
Sep 2, 2015 08:24 PM
