cut off date for 27 - 30 spline 700R4?
Old Oct 23, 2006 | 09:36 PM
tpivette89's Avatar
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
i have an 84' Z28 with the LG4/auto trans combo. ive read that a mid-year change was made to the 700R4 that increased the spline count from 27 to 30. was there a specific date when this happened, meaning i can look up the build date of my car and know which version i have? or to know for sure would i have to drop my tranny?
the reason im asking is cause i want to use a stock torque converter from a GN. they stalled around 2000rpm and would be a stronger alternative to the S10 converter (which didnt last long in my old 89' Vette... i wont use one of those again). apparently, 2004Rs all had 27 splines, so if i had the older version of the 700R4, a GN torque converter should work
any help would be greatly appreciated
Old Oct 25, 2006 | 03:40 AM
Pat Hall's Avatar
You should have a 27 spline converter. They didn't change to the 30 spline version until 87 or 88.
Old Oct 25, 2006 | 06:53 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
I have not yet run across a 30 spline 84 trans. I have rebuilt units made late in the model year that were still 27 spline. I would also like to know the date of the changeover. My gm books contain every other upgrade and the date they occured. The 27-30 spline changeover date is not listed.
Old Oct 25, 2006 | 10:12 AM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
GM says 87 and they also changed the case as well that year.
Old Oct 26, 2006 | 05:22 AM
Pat Hall's Avatar
I don't actually have it in writing anywhere, but I've always heard 87 was the changeover year as well. I'm sure Dana from Pro-Built Automatics would be able to verify that. Maybe he'll chime in on this thread.
Old Oct 26, 2006 | 07:21 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
85 and up have 30 spline.
Old Oct 26, 2006 | 07:23 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
I rebuilt a 700R4 that came from an '84 impala... It was a 30 spline.. So it could be either one... '85 and up is 30 spline though... '87 was a big changeover year for many other things..
Old Oct 28, 2006 | 11:24 AM
tpivette89's Avatar
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
i know for the 88 model year they changed the case apparently, however, im concerned about the spline count changeover
i looked up a few aftermarket torque converters in jegs & summit and it lists 2 different part #s for each brand/kind of converter for the 700R4 - those made from 81-84, and those made from 84 & up. if that info is correct, then there WAS a changeover to the 30 spline trans somewhere in the 84 model year. also, it lists the 81-84 converters for all 700 and 200 series transmissions, which means my assumption that i could use a GN or similar 2004R converter in an earlier 700 trans is correct
i guess theres no concrete "cut-off" date as to when the spline count was changed, so the only way to know for sure is to pull the trans
Old Oct 28, 2006 | 11:35 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
It's 85+ for the 30 spline converter. Not to say a late model 84 would not have one but your going to have to pull the transmission to be certain.
Old Oct 29, 2006 | 12:15 AM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
for the v-8 transmissions, some '84 might have 30 spline input, buit was definite in '85 and up. the v-6 retained the 27 spline(with the exception of the 4.3 liter)
plm99
Southern California Area
Nov 16, 2015 05:21 PM
Thirdgen89GTA
Sep 12, 2015 08:39 PM
Nick McCardle
Sep 10, 2015 08:36 PM
DARKmj16
Sep 9, 2015 04:07 PM
