trans wont downshift at wot
Old Oct 29, 2006 | 09:24 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
For some reason my car wont downshift all the time when i floor it usually ever auto trans i seen at wot downshifts and the rpms shoot up high and the car moves my car slowly gets up to rpms then starts to go. Whats wrong and how can i fix it? Plan on putting a shift kit in it next couple of weeks.
Old Oct 30, 2006 | 09:01 PM
dave-92gta's Avatar
Car: 92 trans am/ 93 dodge spirit V6
Engine: L98 V8 - 350
Transmission: TH-700-R4
i tihk the tv cable is the cable that jsut needs to be adjusted... try that... if its not that i think you should take it to a trany shop
Old Oct 31, 2006 | 06:29 AM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
yeah the tv cable is adjusted
Old Oct 31, 2006 | 08:59 AM
ProjectIrocZ28's Avatar
Car: 88 Monte Carlo
Axle/Gears: Really Tall ones. Probably 2.73's
sounds like a freewheeling stator in the torque converter. an easy way to check is a stall test. if the stall speeds way low, its probably that.
*** be SURE the engine has no problems either!!! lots of "trans" problems are often engine problems
Old Oct 31, 2006 | 08:19 PM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
engine runs fine when i stall up it starts to spin the wheels at 1300
Old Oct 31, 2006 | 11:00 PM
Pro Built Automatics's Avatar
When does the transmission stop downshifting, at what speed? If the TV cable is tight at WOT, then this is correct. If the transmission downshifts at other times 3-2, 2-1, and not a 4-3 downshift at high speeds, then this is ok.
Old Nov 1, 2006 | 06:24 AM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
its only at wot when i mash the paddle sometimes it downshifts hard and picks up speed fast other times it stays in i guess 3rd or 4th gear and takes awhile to clime rpms. Probuilt your just the guy i wanted to talk to im thinking about buying a shift kit from you next week.
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
bamaboy0323
Aug 15, 2015 07:20 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
