need a clutch
Old Nov 10, 2006 | 02:49 PM
dubcity's Avatar
Car: 85 Camaro iroc
Engine: 305ci HO
need a clutch
i got a stock T-5, and now no clutch
what would some people recomend?
thanks
Old Nov 10, 2006 | 03:51 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
CenterForce.
JamesC
Old Nov 10, 2006 | 06:15 PM
dubcity's Avatar
Car: 85 Camaro iroc
Engine: 305ci HO
i have seen them, but whats better
center force I
center force II
center force dual friction
thanks.
Old Nov 10, 2006 | 08:07 PM
JamesC's Avatar
For your application, probably I.
JamesC
Old Nov 16, 2006 | 05:08 PM
dubcity's Avatar
Car: 85 Camaro iroc
Engine: 305ci HO
ok, thanks bud
so if my clutch goes i need new bearings to right?
what do you get in a "clutch disc" that you dont in a "clutch kit"
Old Nov 16, 2006 | 06:28 PM
JamesC's Avatar
You'll need a new pilot bearing/bushing. I assume that if you purchase a clutch disc that's what you get, a clutch disc. IIRC, the kit usually provides a disc, pressure plate, pilot bearing and an alignment tool. Get a kit. And have the flywheel turned.
JamesC
Old Nov 17, 2006 | 06:18 PM
dubcity's Avatar
Car: 85 Camaro iroc
Engine: 305ci HO
JamesC
turned? that mean remachined?
I got a friend whos dad is a mechcanic and has a lift n **** in his garage, he said he would do it for the price of the clutch and a case of corona... Im sure he knows what to do but i just want to make sure what needs to be done is done... alright thanks again.
Old Nov 17, 2006 | 08:16 PM
JamesC's Avatar
Yes.
JamesC
Old Nov 18, 2006 | 01:39 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
machine shops, maybe some mechanic shops would be able to grind down the flywheel. Mine wasn't warped, so I just scuffed it up with scotch brite and cleaned it with brake kleen.
You're lucky if you're not the one aligning the clutch disc - that's a PITA for me.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
Night rider327
Sep 2, 2015 04:18 AM
