Lock up converter
Old Nov 15, 2006 | 09:30 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Lock up converter
How can I tell if my converter is locking up??? On my older car (84 camaro) I could tap the brake, and it would come out of lock up, and RPM up a bit...I even wired a lock up switch in the brake line wires so I could turn it on and off when I wanted...On my 89 tapping the brake makes no RPM change.....Ideas guys???? If its not working, what are the most likely causes???? thanks, for any help, Tom
Old Nov 18, 2006 | 08:11 PM
tom robison's Avatar
Car: 91 ta
wire a push button switch between term A and F on your aldl connector and that should lock your converter, if it don't lock your tcc solenoid needs replaced or a wire is broke.
Old Nov 19, 2006 | 08:45 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Hey Tom, Thanks alot for the info...Where is this solenoid located??? I might just try the switch thing, that would be cool...Will it harm anything (Besides milage) if the converter is not lockingup???? Should'nt you be able to tell when it locks, and unlocks??? On my older thirdgen, I could just barley tap the brake, and it would unlock...Thanks again, Tom
Old Nov 19, 2006 | 11:10 PM
BBCAM's Avatar
Car: 99 Camaro
Engine: LS
Transmission: TH-400
Axle/Gears: 3.25 9"
You should be able to feel it engage at highway speed in O/D if it's working correctly .. as for the switch I wouldent use that as anything except a test device I have seen a few done with a switch burn the trans up when accidently left on when coming off the highway ... checking the wireing and connections would be a good starting point..
83 Crossfire TA
Jan 3, 2016 01:26 PM
Nick McCardle
Sep 10, 2015 08:36 PM
scottmoyer
Sep 7, 2015 07:06 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
