finishing t5 swap0 speedometer leaks
Old Dec 11, 2006 | 08:55 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
the speedometer cable is leaking trans fuild, is there a 0 ring that goes in there or something?
Old Dec 12, 2006 | 05:37 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
There's a small one around the sleeve.
JamesC
Old Dec 12, 2006 | 05:07 PM
jayk2k3's Avatar
Car: 85 camaro z28
where can i get one. can i use a regular o-ring? i hope i dont have to buy a new cable, just 4 that.
Old Dec 13, 2006 | 05:37 AM
JamesC's Avatar
The ring comes with a new sleeve, but I'm unsure if it's sold separately. You won't have to purchase a new cable.
JamesC
Old Dec 13, 2006 | 06:02 AM
jayk2k3's Avatar
Car: 85 camaro z28
is this a gm dealer only part?
Old Dec 13, 2006 | 06:08 AM
JamesC's Avatar
As far as I know, the sleeve itself is. The following link will provide some info:
https://www.thirdgen.org/forums/tran...en+gear+sleeve
JamesC
Old Dec 13, 2006 | 05:15 PM
jayk2k3's Avatar
Car: 85 camaro z28
mine is leaking throw the inside the drive gear sleeve, not the outside
Old Dec 14, 2006 | 05:31 AM
JamesC's Avatar
There's at least one (perhps two, sorry I don't remember) inside the sleeve itself which seals the driven gear. If that seal is worn or cut, you'll have a leak.
JamesC
Old Dec 15, 2006 | 05:44 PM
jayk2k3's Avatar
Car: 85 camaro z28
last question, if the sleeve is good, it wont leak with the cable unhood correct?
Old Dec 15, 2006 | 10:22 PM
jayk2k3's Avatar
Car: 85 camaro z28
anyone????
Old Dec 16, 2006 | 05:16 AM
JamesC's Avatar
If the seals are good, it should't leak much, if at all. The question is why would you want to run the car without the cable attached?
JamesC
Old Dec 16, 2006 | 06:08 AM
jayk2k3's Avatar
Car: 85 camaro z28
thanks 4 the info. i was just trying to figure out, if the sleeve was bad or if the cable had a seal where it screws on, which it doesnt. i will just buy a new sleeve and that should fix my problem. thanks
mustangman65_79
Aug 7, 2015 09:55 PM
JR305
Jul 29, 2003 06:56 PM
chefdan1
Jan 29, 2003 10:01 PM
c4boom
Nov 30, 2002 10:43 PM
90FFBird
Nov 17, 2000 06:12 PM
