700r4 problems
Old Dec 26, 2006 | 10:02 PM
FU_I_AM_UltraZ's Avatar
700r4 problems
i've got a 1989 RS with a the 305 tbi and 700r4 combo. i have a high idle all the time and on cold starts, I can't shift into overdrive. When I do, it acts like it's in neutral. it'll shift into overdrive at 35-40mph from a cold start, but if i stop at a red light, it'll act like it's in neutral. it'll go into overdrive after it warms up good and even then sometimes is stubburned. if i'm going 60+mph and gun it, it'll rev out.. it's slipping i know that, but would that cause the car not to catch in overdrive on a cold start? i know it needs to be rebuild... but i can't shell out the cash right now. i don't know squat about trannys so i hope someone out there can help me out.
Thanks and happy holidays.
-Charlie
Old Dec 26, 2006 | 10:05 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Sounds like worn bands and clutches, you did not mention mileage.
Old Dec 26, 2006 | 10:08 PM
160K
Old Dec 26, 2006 | 10:11 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Sounds like time for like time for a rebuild/replacment.
Old Dec 27, 2006 | 09:57 PM
danandamy's Avatar
Car: 86 Camaro
Have you tried changing the filter? If it's plugged up bad, it may be simply having a hard time sucking enough fluid through the filter to supply the tranny. When the trans is cold, the fluid has drained back into the pan and if the filter is plugged, it will take longer for it to pump the fluid through and thus supply overdrive. Anyway, can't hurt to try it, relatively cheap to do.
camaro11j
Sep 19, 2018 08:49 AM
someone972
Aug 30, 2015 12:52 AM
Frismund Snoid
Aug 27, 2015 11:08 AM
g.l.mos
Aug 22, 2015 12:02 AM
TreDeClaw
Aug 14, 2015 06:58 PM
