vibration around shifter
Old Dec 31, 2006 | 12:40 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
got a little question, i have a vibration that comes up from around the shifter in my car when im at higher speeds and at higher rpm, over 4000, its not the driveshaft as its new a perfectly ballanced, and idears? and its not a constant vib either its hard to explaine, it comes and goes, evenly like 01010101010 if that helps in any way
Old Jun 5, 2007 | 05:33 AM
Dr G's Avatar
Re: vibration around shifter
Did you find the problem? I'm having something similar and am interested in what you found.
Thanks.
Old Jun 5, 2007 | 09:11 AM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
The same symptoms happened to me when my driveshaft was unbalanced. Never had a problem until I put new U-joints in. I guess the slop from the old U-joints took up the out of balance condition. Once new joints were put in, the vibration would come and go, depending on the rpm. A trip to the driveshaft shop fixed it. Like yours, the vibration was most evident at the shifter.
Old Jun 5, 2007 | 05:17 PM
JayBoCC2's Avatar
Car: '88 trans am GTA
Engine: 5.7L 355 TPI L98
Axle/Gears: eaton posi 3.73 gears
your driveshaft may be in perfect balance, but if its even 1/4 an inch too long or too short it will cause vibrations.
mcfastestZ28
Oct 5, 2015 07:12 AM
ndndndnd
Sep 28, 2015 08:00 AM
