VSS
Old Jan 1, 2007 | 01:56 PM
drivera's Avatar
Car: Chevy IROC - Z 86'
Engine: 5.7 TPI
VSS
I just swapped my 2.73 gears for 3.73 gears, my speedometer is off and my tranny is responding a little strange. Do i have to change the VSS to make up for the rear axle? The tranny shifts into 1st and 2nd fine, but it doesnt seem to find 3rd or 4th. And where is the VSS? All this is on a 86 IROC
Old Jan 1, 2007 | 05:10 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
transmissioncenter.com has the speedo gears if its an electric speedo, and for the shifting, that a trans issue, maybe time for a rebuild
Old Jan 4, 2007 | 02:20 AM
Pat Hall's Avatar
An 86 Iroc has a mechanical speedo, the only VSS is on the back of the speedometer, which you don't have to mess with. You'll need to get the correct gear (#of teeth) for the mechanical sending unit, which is located in the tailshaft housing of the trans, and you'll also have to change the trans output shaft gear to the gray 15 tooth one for any ratio that's 3.42 or numerically higher.
$750 L98
Feb 1, 2025 02:25 PM
GTAman
Jul 3, 2024 07:29 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
