How much work is involved with 3.42 gear swap?
Old Jan 6, 2007 | 08:31 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
Transmission: Built 700R4
Axle/Gears: Unknown 9 Bolt Posi, 3.73s
I decided for my first mod, which should be coming up in a month would be new gears and a shift kit.
After research and help from you guys I chose a transgo for my 700-R4, and I chose 3.42s over 3.73s....
So I never found my rpo code, and I had a friend (devestator X) start to help me...
I counted 9 bolts... I'm pretty sure I have 9, could be 10, but I counted 9 from laying on the street...
He also needed my speed at 1500 rpms... I still have yet to do this, due to the winter...
and wheel height or something....
So would my mechanic just swap out the gears and put in my shiftkit? Or is there something I'm missing and I would have to buy more parts to change something....
And does anyone know how much a fair labor cost would be, so I would know if I am getting ripped off for future reference...
-Thanks
Old Jan 6, 2007 | 08:43 PM
Jtufts's Avatar
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
here is an interesting part i found out about the 9 bolts , basicly were ****ed 10's and 12 bolts got it easy finding parts
Originally Posted by Abubaca
Aw come on, ya know ya wanna post!!!!!!
....na, don't mind helpin' at all. The reason you couldn't find 9 bolt gears under the search is because they're numerically different. 9 bolts are 2.77 - 3.27 - 3.45 & 3.70, instead of 2.73 -3.08 -3.23 - 3.42 - and 3.73 like 10 and 12 bolt rears.
Here's the hook -up !
http://www.ringpinion.com/PartsList....b-Differential
-Chris
thats a pm i got from a mod asking him for help after i spent the whole day searching for 9 bolt 3.73's i mean all freaking day
Old Jan 6, 2007 | 08:58 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
so would it be better to go with a 10 bolt rear?
How much are they, and how much work is envolved?
Old Jan 6, 2007 | 09:25 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
Bump
Old Jan 6, 2007 | 10:01 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Count again. A '92 f-body came with a 10-bolt rear end. And a 305 TPI with an automatic came with a 2.73 gear and a 2-series posi carrier. A 9-bolt rear will also have a rubber drain plug in the cover; a 10-bolt will not.
Old Jan 7, 2007 | 05:51 AM
ede's Avatar
ede
you'd need an install kit to go with the gear set, maybe a solid spacer if that's what you want, and oil.
Old Jan 7, 2007 | 12:50 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
there was no way for me to jack the car up since I was in my garage....
So I guess it's 10 then...
Old Jan 8, 2007 | 01:35 AM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
If your going to be swapping gears in the rearend then chances are your planning on driving it harder and so I would at least recommend replacing the bearings and a solid spacer like what ede was sayin. Maybe a rear cover girdle would help as well. Of course you could always have them install the gears and bearing and then at a later date add the girdle and such.
Old Jan 9, 2007 | 05:07 AM
Pat Hall's Avatar
From a cost standpoint, it'd be way cheaper to locate a third or fourth gen rear that already has the ratio you're after. You can usually score one with posi and disc brakes for around $200-$350. To upgrade your original rearend, you're looking at about $200 for new gears, about $100 for the install kit (bearings, shims, crush sleeve, etc.), and usually about $200-$250 in labor for a shop to install them. If you have to buy a new posi carrier, add on another $150-$450 depending on which one you choose. If you're not totally set on having posi and disc brakes, there's tons of 6 cylinder cars in the junkyards with 3.23 and 3.42 ratios stock. Just my .02.
Old Jan 9, 2007 | 05:30 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I'd suggest you make sure.
JamesC
Old Jan 10, 2007 | 02:35 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
Well yea I'm gonna make sure I have the correct number... lol
Old Jan 10, 2007 | 06:53 PM
Andy 91GTA's Avatar
Car: 91 GTA & 92 GTA & 92 GTA
Engine: 305 TPI & 350 TPI & 350 TPI
Axle/Gears: 3.42 & 3.23 & 3.23
I swapped my 2.73s for 3.42s on my 91 GTA last year and it is the best mod I've done to date. I could barely spin my tires in 1st, now I can squawk them most of the way through 1st and also into 2nd (I have a shift kit too though). You have to change your drive and driven gear too so your speedo is correct. If you're going to add a shift kit, I'd get a TransGo, 0.500" boost valve and Corvette servo.
draco
Oct 4, 2015 09:25 PM
jharrison5
Aug 19, 2015 05:53 PM
mizz0313
Aug 12, 2015 06:45 AM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
