9 inch question (posi, limited slip...)
Old Jan 12, 2007 | 05:33 AM
Nonni's Avatar
Car: 86 T/A
Engine: ZZ383
Transmission: TH700R4 Raptor
Axle/Gears: 2,7x -> 3.00 or 3.50
I know this is probably not the best place to ask about Ford stuff but I dont know of any good Ford groups and this is for my 86 TA.
I am going to install a 9" Ford in my TA and dont know what is best to buy to get the power to the ground. I was wondering if Truetrack was the best way to go?
My vehicle is 86 TA, ZZ383 425/460, Raptor 700R4, and 3.50 gearing and this is a street vehicle (weekend vehicle).
Thanks, Nonni
Old Jan 12, 2007 | 05:38 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
how is the weather up there?
truetrack should be fine.
Old Jan 12, 2007 | 05:48 AM
Nonni's Avatar
Car: 86 T/A
Engine: ZZ383
Its ok, we have some snow and the temp is around freezing point. The TA will not get out untill next spring!
Old Jan 12, 2007 | 06:06 AM
EvilCartman's Avatar
Car: '82 Z28
I run a trac loc clutch type in mine, very easy to rebuild.
Old Jan 12, 2007 | 05:13 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Tru Trac by detroit locker would be a good choice. I have one in mine and it is quiet and has no clutches to wear, at the track it hooks dead square, I have never heard a noise out it and and I use full slicks with a trans brake and 700 HP engine... best compromise between a locker and a clutch posi
Old Jan 12, 2007 | 06:51 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
i also have a true trac in my 9". its a real nice piece. it can handle alot of power
Old Jan 12, 2007 | 07:09 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Detroit TrueTrack here also in my 9". So far I like it all though one time my tires were chirping around a corner at 70mph(little scarry), not sure if it needs to be broken in or not or mine is just tight from the factory. Anytime I want it to lock up it's just a matter of steping on it, hundred times better then the stock piece of **** I had before.
Old Jan 13, 2007 | 12:47 AM
Car: '82 Z28
Guess I'm the odd man out here haha. Got it local for a good price so I stuck it in
Old Jan 13, 2007 | 01:52 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i'm going to be running a spool, but the tru trac is a nice piece for more of a cruiser
Old Jan 13, 2007 | 08:27 AM
Nonni's Avatar
Car: 86 T/A
Engine: ZZ383
Thank you all, I have ordered True Track!
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Warlocksirix
Sep 3, 2015 12:26 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
