Want more of a performance gear
Old Jan 15, 2007 | 10:29 PM
ultimatefighter's Avatar
Car: 1992 Z28
Axle/Gears: 10 bolt posi. G80
Hi all! New to this site. I have a 273 limited slip, but want more of a performance oriented gear. What is the highest i can go without swapping the carrier? What is it... a size 2 carrier? Maybe some 3.42?
Old Jan 15, 2007 | 11:16 PM
klause83z28's Avatar
Car: 83 z28
Engine: boat anchor 305 (ex CFI)
Axle/Gears: 3.23 10 bolt
I am pretty sure anything over 3.08 will require a series 3 carrier. So if you wanted 3.42's you will need a new carrier my friend.
Old Jan 15, 2007 | 11:19 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
3.08 is the numerically highest stock ratio you can put on the 2-series carrier you have. However, you can purchase new 2-series gears in ratios of 3.23, 3.42, 3.73, etc, that will work for you.
Old Jan 16, 2007 | 12:18 AM
Car: 1992 Z28
OK. Thanks guys. Where can one purchase the "new" series 2 gears that are numerically higher? Are there any downfalls in using these gears in my carrier?
CarGuyDennis
137
Dec 6, 2016 11:02 PM
1986Z28OWNER
Dec 13, 2015 10:19 PM
beastin91rs
Oct 9, 2015 07:38 AM
Reddeath210
Oct 6, 2015 08:20 AM
zayne0
Aug 24, 2015 07:22 PM
