t-5 swap electrical question
Old Jan 15, 2007 | 10:50 PM
wiggin's Avatar
Car: 89 IROC-Z
Engine: 383 stroker
Transmission: WC T-5
Axle/Gears: 2.77
I'm trying to hook up my clutch switch that is replaceing the old park sensor on the auto, but there are several pair of yellow and purple wires under my dash. How do identify which ones I need to splice into the new clutch sensor?
Old Jan 17, 2007 | 08:16 AM
wiggin's Avatar
Car: 89 IROC-Z
Engine: 383 stroker
Axle/Gears: 2.77
bump
Old Jan 17, 2007 | 09:23 AM
No "splice" should be required. Or any other form of hacking on the wiring, either.
Look in the vicinity of the bottom of the steering column. Find a plug that has nothing in it but 2 big fat wires, one yellow and one purple. Unplug it from whatever it's plugged into. Plug it into the clutch switch. Done. If you find one plug with the 2 wires plugged into another harness that has 2 similar wires, then unplug them from each other, and plug the one into the clutch switch that fits it, and leave the other alone.
Old Jan 17, 2007 | 09:49 AM
wiggin's Avatar
Car: 89 IROC-Z
Engine: 383 stroker
Axle/Gears: 2.77
what where those three wires coming out of the automatic trany? Can i just cut and discard those?
Old Jan 17, 2007 | 01:30 PM
splice
cut
hacking
Why?
Old Jan 17, 2007 | 04:28 PM
wiggin's Avatar
Car: 89 IROC-Z
Engine: 383 stroker
Axle/Gears: 2.77
so is that a no, you dont know what those wires where for?
Old Jan 18, 2007 | 04:33 AM
Pat Hall's Avatar
The three wires going into your automatic are for the torque converter lockup solenoid, which you won't need any longer with a manual trans. You can either cut off that portion of the wiring harness or just tuck it up out of the way. I know some people will disagree with me on this, but I don't believe in having a clutch neutral safety switch anyways. Only a complete idiot would try to start the car while it's in gear without pushing the clutch in first. All I did was splice the yellow and purple wires together, which completely bypasses the neutral safety crap. If you do want the neutral safety to work properly, just splice the correct plug on the yellow and purple wires, then plug it into the switch on the clutch pedal.
Old Jan 18, 2007 | 10:35 AM
Right.
No that is not a "no, I don't know"; that is a "no, you don't need to cut, splice, or otherwise HACK on ANYTHING".
They perform auto-trans-specific functions, and therefore aren't needed.
Why not just tuck them back in to the harness, so that the car could still have an auto put back in it if that comes to be desired someday (by you or by the next owner)?
As far as splicing the yellow and purple wires together, you can accomplish that in a sanitary manner, again, WITHOUT HACKING, by crimping 2 male slide terminals onto a piece of wire about 3" long, and plugging that into the plug. HACK-FREE. Reversible.
I always recommend doing things to wiring in such a way that nothing is permanently damaged or destroyed. You just never know when you might need to put it back like it was (unless your ability to predict the future is better than mine... I bought a crystal ball recently, as you know you can get just about anything on eBay, but it hasn't seemed to help me...), and hacked-up wiring is about 10 times harder to troubleshoot than unmolested factory wiring that matches the prints. Yet another "look into the future" kind of thing. How'd you like to be sitting in a parking lot somewhere late at night with your date, and your car won't start because your wiring hack came unhacked??
DON'T HACK. Instead, plug.
Old Jan 19, 2007 | 08:23 PM
wiggin's Avatar
Car: 89 IROC-Z
Engine: 383 stroker
Axle/Gears: 2.77
I definitely see the wisdom in the non-hack approach. My current problem is there are no yellow and purple wires to be found under my dash. I cant tell for sure, but I'm not totally convinced this is the original wire harness from the factory, or hasn’t seen any major re-work from the previous 3 owners.
Besides color (because that option has failed) is there any other way to identify the neutral switch wires? There are 5 wires going into a plug that used to connect to the auto shifter. Two of these wires are a larger gauge than the other three. Are these the appropriate wires to either splice into the clutch switch or cap together? Thanks for the help.
Old Jan 20, 2007 | 03:43 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Maybe Camaros are different, or they changed things later on, but on my 88 Formula, there was a 2 wire connector for the clutch switch already sitting up near the kick panel.
all I did was take the switch from the doner car and plug it in.
Now, there are two wires you do need to splice into in the shifter area and that is the reverse light wires. I can't remember the colors, but you will need the connector and wires going from the trans up to the shifter area, then splice into the wires for the reverse lights.
Old Jan 20, 2007 | 03:54 AM
Pat Hall's Avatar
The two heaviest gauge wires should be the ones. They're usually 8-10 gauge wires on every car I've messed with. Then like Zepher said, you'll want to take the two wires for the reverse lights out of the same plug and wire them into the reverse light switch on your manual trans.
MustangBeater20
Oct 29, 2022 09:20 PM
Jorlain
Aug 24, 2022 05:11 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
mizz0313
Aug 12, 2015 06:45 AM
