Crap! Did I goof up the brake install on my 9 inch?
Old Jan 20, 2007 | 05:16 PM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
So I got the whole 9 inch installed and put together. I pulled the drums off so I could adjust the star adjuster so there would be just a little bit of drag. Then I noticed, "hey, my parking brake cable should hook up." So I assembled the driver's side unit with my big long cable going around the back plugging into the rear. Then I go to the front and alas, unlike my old setup the access whole for the passenger side is in the rear instead of the front. Then I think to myself, are these self adjusting drums and if so, did I put them on backwards? They are 11" ford drum brakes, I think the same ones that an explorer has on them. I don't see a difference in size between the shoes (a primary or a secondary) but one side, the sides facing the front of the car, has a wire running from the top to the lever sitting against the star adjuster. Any help is appreciated. I really don't want to switch these things to the other side, but if I have to.
Also, a u-joint question...
I measured wrong and got the u-joint installed for a 1350 yoke (1 3/16" cap diameter, I forgot the length of the u-joint). I now need a conversion u-joint with that diameter cap and for the pinion yoke 1 1/8" caps. Any ideas as to part numbers? I left the u joint length in the car, but I could get it if anyone needed it.
Thanks,
Mike
Old Jan 20, 2007 | 05:20 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
that cable for the adjuster should be on the trailing side of the assembly...I think that the u joint for a 1le shaft and a 1350 short pinion is a 447X at napa
Old Jan 20, 2007 | 10:57 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
Save yourself the headach and get a yoke for a 1350 u-joint. They are cheap and it will be much stronger!
Old Jan 20, 2007 | 11:42 PM
burntblues's Avatar
Car: 1989 Camaro RS
good point. Problem is though that I just had this driveshaft cut. I don't want to pay for another lengthening or shortening. Wonder if i could get a yoke the same length?
Vintageracer
Jan 10, 2020 05:33 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
kyleb24
Aug 15, 2015 08:24 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
