All 700r4's work?
Old Feb 4, 2007 | 04:57 PM
jlc84cam350's Avatar
Car: 84 camaro, 92 yota 4runner
Engine: 305 lg4 out of 81 z28
Transmission: th350
Axle/Gears: Not sure believe its 3.23
All 700r4's work?
Will any 700r4 out of any model car or year work in a third gen camaro, as long as its 2wd. I hear you can't use the ones from the small v6 blazers or something along those lines, is this true. And are their certaine 700r4's better. Newer is better right?
Old Feb 4, 2007 | 04:59 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
The corvette transmission used from 84-93 will not work. There is no mount boss on the trans.
Old Feb 4, 2007 | 05:00 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The only ones that you can be sure will bolt right up without any trouble will be out of an F body. Transmissions from other 2WD applications (except Corvettes) will work if you swap the tailshaft housing for one from an F body that has the torque arm mount. The bellhousings are different for the V6 and V8, so you need to make sure you have the right one for your engine.
camaro11j
Sep 19, 2018 08:49 AM
Reddeath210
Oct 6, 2015 08:20 AM
TreDeClaw
Aug 14, 2015 06:58 PM
djmarch
Aug 11, 2015 10:22 AM
Leggman1
Aug 6, 2015 04:15 AM
