What fluid 88 T5 WC atf 3 syn or a synchromesh
Old Feb 10, 2007 | 11:20 AM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
I have dex 3 castrol sun tec in there now I was wondering if I should use another atf 3 such as castrol,mobil 1 or amsoil, or should I use teh amsoil,redline royal purple or gm synchromesh. I don't want to shorten the life of the tranny at all. Thanks
Old Feb 11, 2007 | 11:40 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
The fluid won't matter that much, its the beating it that kills t-5s. I won't use anything with a bunch of additives. Just your regular dexron III would be best.
Old Feb 12, 2007 | 11:32 AM
BLACK Z's Avatar
Car: 86 Z28
So mobil 1 amsoil or castrol syn tech should be fine?
Old Feb 12, 2007 | 03:28 PM
kaptinkafeen's Avatar
From what I have read, and inquired about, Dexron should be fine, but under sever use/driving conditions I would go with a synthetic alternative like the mobile, red line etc....I just finished rebuilding my WCT5 and intend to run the car on the track, synthetic fluid should help keeps temps in the trans down etc...etc and provide all the other 'benifits' of synthetic fluid.
-Andrew
Old Feb 13, 2007 | 06:24 AM
BLACK Z's Avatar
Car: 86 Z28
I see the red line royal purple and amsoil all make a mtf or a sycromesh fluid they recommend i just don't want to hurt the trans, it was beefed up when it was rebuilt and it is the nicest shifting tranny I have ever used( I have used alot of them).
Old Feb 13, 2007 | 07:44 AM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
sorry to highjack but what oil does a non WC need? in the computers at work it says it takes dexron 2 automatic trans fluid but someone told me it needs a 80-90w oil?
Old Feb 14, 2007 | 05:27 AM
Pat Hall's Avatar
DexronII only applies to WC units. They require it because there's a fiber/paper clutch lining in the synchro assemblies that's the same material as the clutches in an automatic trans. Non-WC units require 80-90 wt. gear oil. The bearings in the non-wc trannies need a more viscous lubricant, hence the need for gear lube. I've also heard of people running 30 wt. motor oil or even ATF in them, but GM says gear oil in the shop manuals. They probably shift a little slicker with the lighter fluids, but it could be detrimental to the life of the bearings. Btw, Synchromesh is what Tremec says to use in their TKO trannies. I don't know if it's good for T5's or not.
meeklay812
Oct 1, 2015 03:46 PM
FireBirdKnight
Aftermarket Product Review
May 10, 2006 08:09 AM
92GTA
Jun 8, 2002 09:45 PM
five7kid
Apr 27, 2001 04:56 PM
ev305tpi
Mar 20, 2001 05:30 PM
