need help finding the right stall for my TPI
Old Feb 13, 2007 | 03:14 AM
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
so i got my trans pulled and to the shopfor the leak it had. i found out it has a bad converter and a bad pump. im havin them in stall a new pump, but im not sure what stall i want in the truck now. it had a 2200 b&m holeshot in it. i have a stock coverter that will work....or should i buy a new one? also ho much of a stall do i want to run with the built TPI i have? the motor has a ton of TQ down low but im still not sure i doin somthin like a 2500 would be better then say a stock or 2200 stall. need imput asap!! i need to look back on my time slips but i think with the 2200 i would run like a 2.1 2.2 60foot when i ran slicks.
-TireFryr-91-5.7TPI.40over-comp212-218,487-495,110-hypert flattops-1.52rollers-portededelbrock high-flowbase-ported SLPrunners-ported plenum, BBK52mm, Built 700r4, 2200B&M stall,Hurst v-matic2,3.73 posi "TractionLess" ET:14.9@90mph
Old Feb 14, 2007 | 05:34 AM
Pat Hall's Avatar
Looking at the specs of your cam and rearend gears in your sig., you'd probably benfit by going to a 2500, maybe even a 2800.
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
Wade787b
Sep 29, 2015 01:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
