9 bolt only has 7 bolts in it?
Old Feb 14, 2007 | 09:31 PM
1988-305-tbi's Avatar
so i was at the junkyard today and came across an 89 transam, it's a 9 bolt rear end and it has disc brakes, the problem is theres only 7 bolts actualy on the cover, and most of the differentials i see at the junkyard are missing a bolt or 2???????????? is there a reason for this, its still real greasy all the way around the cover so i'm assuming no one removed it, maybe some one just snagged the bolts off it, it seams like most of them are missing a bolt, it makes no since, do the junkyards do this, to drain fluid or something?
and on a further note is there any way to check if the posi is good before i install the whole rear?
anyhow 2morrow im degreasing it and spray painting it black and ordering new ebrake cables, any suggestions on other things i should do to it while its out of the car, i dont have alot of money so i'm not changing the calipers/ rotors unless theyre bad, this is a big upgrade for me......coming from the stock 2.73/drum/ peglegger, sorry for the long post...i'm excited
Old Feb 15, 2007 | 09:38 AM
z28man355's Avatar
Car: 87 camaro
Engine: 355
Transmission: 2800 stall 700r4
Axle/Gears: 7.5 4.10 auburn posi
If I understand correctly most junkyards do drain the fluids to help keep epa off their backs so the missing bolts might be explainable.
to ck the posi hold the pinion and try to rotate one axle while the other is held. There is a torque spec for this rotational resistance but can't remember off hand
Old Feb 15, 2007 | 10:17 AM
And this would be a problem.... how?
Stimpy goes to the boneyard alot, and just takes stuff apart and throws it to the 4 winds. And of course, Skillet is always there too, just breaking stuff to pieces so he can get to whatever little bit he wants and steal it. That's why you see every dash laying on the floorboard in little fragments, and the odometer gone. The junkyard won't generally sell the odometer because they know that people who want to buy just that are trying to defraud the world at large; so Skillet just trashes a whole car and steals it. Skillet also removes all radios from the dash with a pickaxe, which is why EVERY dash in EVERY car in EVERY junkyard is COMPLETELY MULTILATED AND WORTHLESS where the radio goes.
Look around on the ground and find the rest of the bolts from where Stimpy looked at the gears and discovered that it was a 2.xx instead of something decent, and decided that wasn't the one he wanted, and just half-a$$ed it somewhat back together.
In fact, I'd go so far as to say that if cover bolts are missing, that's EXACTLY what it means; somebody has already been inside there. And either it's toast, or they stole some small part, or it's one of the non-desirable ones and they didn't want it and you won't either.
Old Feb 15, 2007 | 10:42 AM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
Unless someone just wanted the tags to put on their diff.
Old Feb 15, 2007 | 11:19 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Well said!
Old Feb 15, 2007 | 12:19 PM
chesterfield's Avatar
Car: Pontiac
Like the Z28man said. You didn't see a puddle of fluid under any of those cars did you. I'll bet every car in that yard has a puncture hole in the gas tank too, where they skewered it and drained it before they brought it out.
Old Feb 15, 2007 | 06:42 PM
come to think of it evey brake master cylinder is always empty, never seen any motor oil, or trans fluid, o'm guessing that the yard probaly did it, well i'll open it up anyhow and check for my self, thanks for the replys
Old Feb 15, 2007 | 08:08 PM
i pulled the cover.... there was about 1 tablespoon of fluid in it..... and i didnt want to try to count the teeth so i marked the rotor and counted how many times of spinning the drive shaft yoke on the carrier to determine the ratio and i got 3.25, so i'm, happy that i didnt grab the 2.77 by accident so i def. have a 3.27.... and it looks like everything is entacted
Old Feb 15, 2007 | 09:32 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
I just did this swapp 2 weeks ago, and it makes a HUGE difference......It will probably be a 3.23..(At least mine was) You need to change the prop valve under the master cylinder....(I tried without doing it, and no brakes) Im not sure how good my posi is, it does work tho...I went and cleaned and painted it 3 trips to the carwash, and lots of wire brushing....It looks really good...Paint your sway bar, and panhard, and trailing arms, it will look good...YOU WILL BE VERY HAPPY.......2.73 open rearends SUCK.......Now when I hammer it my car kinda fishtails, but really takes off alot faster.........If you can change your bushings while your at it, check your shocks too, mine were shot...Good luck...Tom
Old Feb 15, 2007 | 09:45 PM
do ur brakes work a lotr better than the old drum setup, i hope so, i already have tubular powder coated trailing arms/ panhard, and painted sway bars, i have all new supspension/bushings, i plan on degreasing the heck outa the rear and painting it gloss black, i might paint the new 24 mm bar black also, i now have 2 24mm sway bars one blue and one rusty, for now. it's a 3.27 for sure only rearends available were 3.27/2.77, and its def. not a 2.77
Old Feb 16, 2007 | 07:24 AM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
uh, I thought the gear was 3.23...According to my RPO book it is, but whatever its close as can be...I counted the same way you did.....Was wanting a 3.42, but this is alot better than what I had......NO the brakes are not much better, if at all....BUT I had just rebuilt my back brakes, so they were in good shape....THEY LOOK ALOT BETTER THRU THE WHEELS.....I hate brake bleeding....Also, I might still have a drop of air in the lines......I think to get the full effects of rear disc, you really need braided steel lines.(Next project) The car is so much quicker now..My car has never been a great stopper tho........Tom
Old Feb 16, 2007 | 08:01 PM
i have braide steel brake line, only thing that suks is that theyre for the front disc/ rear drum setup, so i'm going to buy a new set and sell my old ones, some where down the line, i'll just be happy to be rid of the 2.73/pegleg
Old Feb 19, 2007 | 01:53 AM
Pat Hall's Avatar
Hey Galileo, the 3.23 ratio is a 10 bolt ratio. The 9 bolt ratio that's equivalent to that is 3.27. In addition to 2.77 and 3.27, there's also 3.45, which is the 9 bolt equivalent to 3.42 in a 10 bolt. The 3.45 ratio is very uncommon though. Most of them were 2.77 or 3.27. Sofa's little rant about "Stimpy" and "Skillet" is so true no matter what yard you go to, unless it's one of the overpriced yards where everything is inventoried on shelves and nobody's allowed to enter the yard. I remember when I needed a fuel line, and the yard I went to had cut the fuel lines on every single car to drain the gas, so that sucked. But as mentioned above, draining all fluids possible before the car enters the yard helps keep the whiny tree-huggers off their backs.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
billybob6110
Sep 23, 2015 01:30 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
