do I need a new speedo gear housing?
Old Feb 20, 2007 | 07:48 PM
longhorn450's Avatar
Car: 1990 Trans Am
Engine: LB9 305...350 or 383 coming soon
Axle/Gears: 4th gen 3.42
I went from a 1990 2.73 thirdgen rear to a 3.42 4th gen rear and the speedometer is (obviously) off. I know that this car has a VSS and I just want to make sure that the ONLY parts I need are:
-15-tooth drive gear (gray), GM#8642620
-41-tooth cone-shaped driven gear (yellow), GM# 25513048
I need to order these parts soon but I just wanted to make sure first. Thanks!!
Old Feb 20, 2007 | 07:53 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
You are correct sir. I did the same swap.
Old Feb 20, 2007 | 07:56 PM
Car: 1990 Trans Am
Awesome. Thanks for the quick reply. Also, when people talk about needing a different driven gear housing (35-39, or 40-45), does that only apply if they have a mechanical speedometer cable?
Old Feb 20, 2007 | 07:58 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i went from 2:723 to 3:73 and didnt change housings, works fine
Old Feb 20, 2007 | 08:08 PM
Car: 1990 Trans Am
alright, that definetely simplifies things.
Old Feb 20, 2007 | 09:20 PM
Car: 1990 Trans Am
One more question...In order to get the VSS out, do you just remove the sensor plug, the bolt, and then pry it out or what?
Old Feb 20, 2007 | 09:23 PM
krisb410's Avatar
Yup on the removal. And I have both types ofVSS (one is white, one is black) and there was no difference when I used the correct gear on either unit, so I'm not quit sure why they had 2 VSSs
Old Feb 20, 2007 | 09:26 PM
Car: 1990 Trans Am
What exactly is the difference between the white and black VSS's? Thanks for all you patience...
Old Feb 21, 2007 | 12:13 AM
krisb410's Avatar
I asked the same question when I was doing the swap. The only info I found is that the black one was for the gears with less then 40 gears, and the white one is for gears with more than 40 teeth. I put the yellow gear on both the white VSS and the black VSS. Same result on the speedo. So I dunno what the difference is, but the speedo has the same readout. I determined my speedo was indicating correctly by being paced by the same vehicle.
Don't worry, use the same VSS that you have.
Old Feb 21, 2007 | 05:18 PM
Car: 1990 Trans Am
thanks krisb, that helps a lot!
Old Feb 21, 2007 | 05:33 PM
krisb410's Avatar
Anytime bro, feel free to IM me if needed, I'm about to do a 3.32 4th gen posi disk swap
Jeremys87
Jul 14, 2022 09:08 PM
Eric2ndGen
Nov 5, 2015 01:51 PM
Orr89RocZ
Oct 7, 2015 12:47 PM
madsv1000
Aug 20, 2015 06:45 AM
