Trans not fully disengauging
Old Mar 1, 2007 | 09:11 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
What would cause an auto to not fully disengauge?
I can be rolling down the road, put the car in neutral, hit the gas, and my car will actually accelerate for a second. Also, I pulled my car into the garage one day, put it in park, and the POS jumped forward about 2 inches. That 2 inches was about a half inch too far. Hit my engine hoist and cost a small fortune to fix my paint.
Old Mar 1, 2007 | 10:38 AM
krly79's Avatar
Car: '93 S10 Short bed standard cab
Engine: 383 Stroker
Transmission: 92' stage 2 700r4 w/3600 stall
First thing I would do is check the linkage to make sure it is adjusted properly.
Old Mar 1, 2007 | 11:09 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
If it is internal, I would suspect the forward clutch pack. If they overheat, the clutches drag the warped steels allowing a partial engagement.
Old Mar 1, 2007 | 05:01 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Krly - linkage? The TV linkage? That is adjusted correctly.
Floor - Forward clutch pack sounds like rebuild time. If so, can't wait till i'm back together and the roads are clean so I can beat the crap out of it. Gotta make it fail a little more.
db057
Sep 4, 2015 07:57 AM
Thornburg
Mid-West Region
Aug 25, 2015 08:20 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
1989formula5.7l
Aug 15, 2015 11:35 AM
