93-97 LT-1 T56 Slave Cylinder Spacer?
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
Does the LT1 T56's have a spacer that goes in between the bellhousing and the slave cylinder? My fork protrudes a 1/2" past centerline and actually out of the bellhousing. I think it needs a spacer to space out the slave form the fork to compensate for the fork protruding.
Car: 90 Camaro RS
Engine: 305 TBI
there is indeed a spacer...although i cant confirm the part number at this time.
another name for it though is: clutch actuator adapter
Car: 92 z28
Engine: fast burn 385
Transmission: t56
what is this spacer for? does it go on the studs from the bellhousing? im having some issues with my t56 swap and wondering if this migt be something i need
Car: 92 Z28 Camaro
Re: 93-97 LT-1 T56 Slave Cylinder Spacer?
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
The dealer should be able to get the numbers for the studs also.
Car: 92 Z28 Camaro
Try this:
Slave cylinder adapter stud (Qty 2 - P/N 12524506 )
Corresponding nuts:
Slave cylinder mounting nuts (Qty 2) P/N 11516071 )
Don't know if thats it or not.
Corresponding nuts:
Car: 92 Z28 Camaro
i can make as many clutch cylinder adapter brackets (GM part #12523315) as you need. aluminum, time and labor, costs $129.95 plus $10.00 standard shipping. you can contact me at (317)409-4399 or at josh79camaro@hotmail.com
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
https://www.thirdgen.org/forums/tran...er-spacer.html
Car: 87 GTA
Engine: L98 5.7 24#inj,World hds,MSD,nosmog
Transmission: 700R4 truck clutches,Trans go shift
Axle/Gears: 10 bolt chevy 3.73 limited slip
GREAT TIP FOR THE SPACER. everybody else wants $60.00. $11.92 beats the hell outa that
Car: 91 Firechicken
Engine: 355ci SBC
Transmission: 97GM BW T-56
Axle/Gears: 9", Moser 31 Splines 3.73s Trac Loc
How the hell do you order it? Just gotta call them or what?
88SS6SPEED
Nov 11, 2015 07:05 AM
camaro1185
Oct 26, 2015 06:51 AM
el_muerte
Sep 16, 2015 12:01 AM
armybyrd
Sep 15, 2015 06:06 PM
