Where to buy ring and pinion
Old Mar 7, 2007 | 08:03 PM
ultimatefighter's Avatar
Car: 1992 Z28
Axle/Gears: 10 bolt posi. G80
Hi, I have the 2.73 posi in my 1992 Z28. I have been told i can run up to a 3.73 gear without changing the carrier with some new "special" gears for this swap. But, i can't find any. ANybody know where to look? Thanks
Old Mar 7, 2007 | 09:01 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
do a google
randysringandpinion.com has sets and tech info pages that explains carriers and breaks too,
summit racing
jegs
and so on, theres a billion other places that carry gear sets
they do make 3.73 gear sets for carrier series that they wold not have come with from factory yes, different thickness gear, than what the factory used
usually thicker, and would require special longer bolts
for all the money it would take to do all this you could pick up a basic 3.42 or 3.73 drum axle for the same or less, usually dirt cheap since they are common, especially around 83 84 85 86 years in the L69/auto trans cars
good luck
Old Mar 8, 2007 | 03:26 AM
ede's Avatar
ede
or you can run the standard thickness gear and a spacer
Old Mar 8, 2007 | 06:05 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Randy's Ring and Pinion set me up with 3.73 (thick) gears that were installed onto my 2 series carrier. Didnt need replacement bolts, re-used the originals. You will also need at least the mini installation kit. I also ordered and installed a solid spacer that replaces the crush sleeve. It comes with shims and instructions.
Old Mar 8, 2007 | 08:49 PM
bahsarie's Avatar
Car: 89 IROC-Z T-top C&C
i have a set, they are a little rusty as they have sat for some years but should be able to be cleaned off, shoot me an offer if you want
6speedIROC
16
Mar 15, 2023 08:33 PM
F-body driver
Mar 6, 2023 11:44 AM
DARKmj16
Sep 9, 2015 04:07 PM
BOOT77
Sep 5, 2015 03:55 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
